carlosking450 158 #26 Posted June 28, 2017 Bueno hemos seguido con la restauracion despacito pero bien,esta vez a tocado preparar algo de chapa. 3 Share this post Link to post Share on other sites
carlosking450 158 #27 Posted September 5, 2017 After several weeks I have managed to advance a lot. <blockquote class="imgur-embed-pub" lang="en" data-id="a/r42fY"><a href="//imgur.com/r42fY"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> 2 Share this post Link to post Share on other sites
carlosking450 158 #28 Posted September 5, 2017 The gearbox is in very good condition only if you change bearings and seals 6 Share this post Link to post Share on other sites
C-121uk 183 #29 Posted September 5, 2017 Excellent job! Share this post Link to post Share on other sites
carlosking450 158 #30 Posted September 5, 2017 Very thanks Share this post Link to post Share on other sites
carlosking450 158 #31 Posted October 12, 2017 Good morning friends, I need to continue with the repair of my 702 I would like to know how the cables of the starter and accelerator are placed, could you put photos to me? thanks Share this post Link to post Share on other sites
wheelhorseman 3,232 #32 Posted October 12, 2017 (edited) Edited October 12, 2017 by wheelhorseman 1 Share this post Link to post Share on other sites
carlosking450 158 #33 Posted October 12, 2017 Thank you wheel horseman but I need photos with the fasteners to go by placing the throttle cable and starter Share this post Link to post Share on other sites
wheelhorseman 3,232 #34 Posted October 12, 2017 Ok I can get some this afternoon Share this post Link to post Share on other sites
carlosking450 158 #35 Posted October 12, 2017 thank you very much very kind Share this post Link to post Share on other sites
wheelhorseman 3,232 #36 Posted October 12, 2017 (edited) Is this what you need? Edited October 12, 2017 by wheelhorseman 1 Share this post Link to post Share on other sites
carlosking450 158 #37 Posted October 13, 2017 Yes very thanks¡¡¡ Share this post Link to post Share on other sites
carlosking450 158 #38 Posted October 26, 2017 Hola otra vez mis amigos, les presento nuevas imágenes de mi WHEEL HORSE casi terminado, solo pinto el capó y la instalación eléctrica.Agrandar esta imagen Haga clic aquí para verla en su tamaño original.Agrandar esta imagen Haga clic aquí para verla en su tamaño original.Agrandar esta imagen Haga clic aquí para verla en su tamaño original.Agrandar esta imagen Haga clic aquí para verla en su tamaño original.Agrandar esta imagen Haga clic aquí para verla en su tamaño original.Agrandar esta imagen Haga clic aquí para verla en su tamaño original.Agrandar esta imagen Haga clic aquí para verla en su tamaño original. carlosking450 Hard Driver Número de mensajes : 90Edad : 39Ubicación : Madrid (España)Tractores : Lanz D3016; Pascuali 991EFecha de ingreso : 12/08/2013 3 Share this post Link to post Share on other sites
Texas Todd 1,025 #39 Posted October 26, 2017 ¡Hola Carlos! Se ve genial. Has hecho un muy buen trabajo. Sigan con el buen trabajo! Share this post Link to post Share on other sites
carlosking450 158 #41 Posted October 30, 2017 On 13/10/2017 at 12:40 AM, wheelhorseman said: ¿Esto es lo que necesitas? Hi, my friend, I have a question about the accelerator cables that I bought, the tip of the new cable is straight and the old one is bent like an "s" so that it does not escape, should I bend it with a pliers to the new cable? Share this post Link to post Share on other sites
carlosking450 158 #42 Posted October 30, 2017 Hello, can someone tell me what has a mobil tab on the top feet? Share this post Link to post Share on other sites
Texas Todd 1,025 #43 Posted October 31, 2017 If I understand what you are asking, the pedal engages the PTO and the tab folds over to hold the pedal down, thus keeping the PTO engaged. Share this post Link to post Share on other sites
wheelhorseman 3,232 #44 Posted October 31, 2017 (edited) 6 hours ago, carlosking450 said: Hi, my friend, I have a question about the accelerator cables that I bought, the tip of the new cable is straight and the old one is bent like an "s" so that it does not escape, should I bend it with a pliers to the new cable? Yes you are referring to the throttle cable they come straight on the end so you can cut them to the length so to answer your question yes install it in place then cut it to the length that you need then put the bend in it - here is what he is referring to. Edited October 31, 2017 by wheelhorseman Share this post Link to post Share on other sites
carlosking450 158 #45 Posted October 31, 2017 8 hours ago, wheelhorseman said: Sí, se refiere al cable del acelerador, vienen directamente en el extremo para que pueda cortarlos a la longitud suficiente para responder a su pregunta. Sí, instálelo en su lugar, córtelo a la longitud que necesita y luego colóquelo. Aquí está a lo que se refiere hello friend, I imagined it but I wanted to make sure, thanks! 10 hours ago, Texas Todd said: Si entiendo lo que está preguntando, el pedal se acopla a la toma de fuerza y la lengüeta se pliega para mantener el pedal hacia abajo, manteniendo así la toma de fuerza activada. If I meant that, but mine does not have a PTO, thank you Share this post Link to post Share on other sites
