Jerry77 1,218 #1 Posted February 19, 2017 (edited) http://www.carrollstream.com/20HP-Gas-Engine-With-Electric-Start-p/2v77.htm Anyone know anything about this outlet?? Doesn't give the length of the shaft but it is available in 1-1/8 inch $739 including shipping... ?? Should have looked further in the ad - lots of motors at good prices....what do you all think? Edited February 19, 2017 by Jerry77 Share this post Link to post Share on other sites
pfrederi 18,638 #2 Posted February 19, 2017 Some people have used the Carroll Stream diesels and didn't report issues. i would want to know if they have ball bearing on the crank shaft or at least some thrust bearing to take the end loading of a WH PTO. If not you cold use an electric PTO but I personally do not care for the sudden engagement of the electric PTO 2 Share this post Link to post Share on other sites
varosd 1,185 #3 Posted February 19, 2017 interesting only a 6 amp charging system? Share this post Link to post Share on other sites
pfrederi 18,638 #4 Posted February 19, 2017 3 minutes ago, varosd said: interesting only a 6 amp charging system? You are right not much...but the fixed 3 amp systems on some of the 300 series horses were adequate to recharge the battery for starting. Any lighting however would have to be LEDs but you can get a lot of light for 3-5 amps these days Share this post Link to post Share on other sites
Jerry77 1,218 #5 Posted February 19, 2017 2 hours ago, varosd said: only a 6 amp charging system Yeah, that isn't much -- looked further thru the ad - they have some good named engines with good specs at what I would consider a good price..,. just don't know if this is a good source or not...it was just for info anyway... Share this post Link to post Share on other sites
SALTYWRIGHT 861 #6 Posted February 19, 2017 I HAVE USED 2 OF THERE DIESELS AND NEVER HAD TROUBLE. VERY GOOS SERVICE. RUSS 2 Share this post Link to post Share on other sites
953 nut 59,788 #7 Posted February 19, 2017 12 minutes ago, SALTYWRIGHT said: RUSS Glad to see a post from you, how are you doing? 1 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #8 Posted February 20, 2017 I AM DOING BETTER NOW. I BROKE MY BACK IN JAN SO IT HAS SLOWED ME DOWN SOME. RUSS 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #9 Posted February 21, 2017 14 hours ago, SALTYWRIGHT said: I AM DOING BETTER NOW. I BROKE MY BACK IN JAN SO IT HAS SLOWED ME DOWN SOME. RUSS Russell I've overlooked this somehow. My goodness! That sounds terrible! What the heck? Share this post Link to post Share on other sites
