Adams94 1,069 #1 Posted February 19, 2017 Going to change engine oil and hydro in dad's 520h he got in the fall. Why oil does everyone recommend to use in these? Share this post Link to post Share on other sites
ericj 1,579 #2 Posted February 19, 2017 the factory recommends 10w30 in engine and trans on the 520-H, a lot of guys are using full synthetic oil in trans like mobile 1. I have used Mobile 1 in 1 or 2 trans so far, but it is not totally necessary. eric j 2 Share this post Link to post Share on other sites
squonk 45,556 #3 Posted February 19, 2017 Use Mobil 1 in the trans. Higher shear strength and heat capability. While you're in there, clean the fins on the trans pump. 1 Share this post Link to post Share on other sites
Adams94 1,069 #4 Posted February 19, 2017 Ok thanks guys! Share this post Link to post Share on other sites
cleat 8,741 #5 Posted February 19, 2017 I run SAE30 in the engines year round. Any tractor that is to be run in the winter is kept in the heated shop. 10W30 in the rear end. Cleat 1 Share this post Link to post Share on other sites
Adams94 1,069 #6 Posted February 19, 2017 How many quarts does rear end hold Share this post Link to post Share on other sites
Toro Bill 10 #7 Posted February 20, 2017 Manual says tranny holds 5qts, but it also says to fill with 4 quarts and add as need to get to fill line. Also be sure to change your filters! I'm partial to Wix but feel free to cross reference, FYI...NAPA Gold is same filter and number but without the 5 on the front. Engine- 51762 Tranny- 51521 Like sqonk says, make sure to keep the fins clean on both engine and tranny. I run Mobil 1 10-30 in both with 3000hrs and counting.... 1 Share this post Link to post Share on other sites
