seven 202 #1 Posted February 18, 2017 It has good spark and it is getting fuel into carb fuel pump is pumping but still can't get it to fire much . Ran last fall when I parked it. It even ran up until I ran it out of gas two weeks ago. It has a h10 c plug in it . Share this post Link to post Share on other sites
pfrederi 19,783 #2 Posted February 18, 2017 You have 2 threads now. Same issue. How do you know you have spark, tester, laying it on the head? Does it run when you spray gas/carb cleaner into the carb??? Did you gap the points??? Share this post Link to post Share on other sites
seven 202 #3 Posted February 19, 2017 It has spark laying it on the head.will not run with starting fluid. I'm trying to get it timed now but not sure how to Share this post Link to post Share on other sites
953 nut 63,916 #4 Posted February 19, 2017 21 minutes ago, seven said: trying to get it timed now but not sure how to X2 Kohler static_timing.pdf Share this post Link to post Share on other sites
oldlineman 1,628 #5 Posted February 19, 2017 (edited) The spark plug may fire on the head but may not fire when installed, under compression. I would try a new plug they are not that much money. Edited February 19, 2017 by oldlineman 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted February 19, 2017 Properly clean and gap the points. 1 Share this post Link to post Share on other sites
