clueless 3,359 #1 Posted February 14, 2017 After decarbing the K241 started to put the head and new gasket on, got all 9 of the original bolts and washers. 8 bolts are 1.5' long 1 is 1.75' long. I numbered the top of each with a sharpie when I removed them but then I cleaned and wire brushed them with carb cleaner, now no sharpie marks,duh! Does the longer one go in a certain hole. Share this post Link to post Share on other sites
WHX?? 55,619 #2 Posted February 14, 2017 If I remember right there should be two longer bolts to go where the S/G bracket sits...someone correct me if I am wrong.... according to the missus I usually am! 4 Share this post Link to post Share on other sites
pfrederi 20,037 #3 Posted February 14, 2017 Was there a metal tab hook on the top of the motor. if so it gets the long bolt 3 Share this post Link to post Share on other sites
clueless 3,359 #4 Posted February 14, 2017 Thanks Jim, but this is a later K241, no S&G. No hook, but that sounds right. The hole on the corner near the intake valve is a thru hole probably going to put it there. 2 Share this post Link to post Share on other sites
WHX?? 55,619 #5 Posted February 14, 2017 My bad then Chris ...missus is right but don't tell her please... all my older horses are S/G! My bad then Chris ...missus is right but don't tell her please... all my older horses are S/G! Share this post Link to post Share on other sites
