AMC RULES 37,254 #26 Posted September 10, 2020 Oh! Here we go again! Yes, it's dishwashing liquid...you know you're soaking in it right? C'mon buttercup, suck it up! Share this post Link to post Share on other sites
bottjernat1 2,196 #27 Posted September 10, 2020 On 2/14/2017 at 5:44 PM, formariz said: Well, call me crazy but here is what i decided to do with the "Jay Bee" muffler on the Electro 12. It was not bought for it but it needed one so I decided to use it. There is no room in front of engine and behind hood for it. From the air filter to the hood everything interferes.If the muffler's body was about 3" shorter then with some clever plumbing it would work but still be tight. If hood was as wide on bottom as on top even better, but it is what it is on this model. When I got this tractor from Ken B. it had a long muffler mounted horizontally which is the best way for this model as you can see on first photo. The only draw back was that the outlet on long muffler was too close to operator and one winds up having some exhaust on the face area. So based on how it was then I mounted this one also horizontally. Since it has the outlet on the side with the long pipe exhaust is directed much lower than before. No interference with PTO or implement belt changes. I will also probably fabricate an extension and have it directly under foot board aimed away from tractor. Fabricated metal bracket to attach to mufflers bracket for additional support . The Electro was always a noisy tractor specially at full throttle. Although still a bit noisy compared to others now one notices engine noise rather than muffler. At idle it is very quite and at full throttle it has a nice "throaty" sound. Sounds really solid unlike before. The original muffler fell apart inside with the loose baffles actually plugging the exhaust outlet and I bought another one like it for about $35.00 only to have exactly the same thing happen after one year. This muffler is heavy at 3Lbs 9-1/2ounces compared to a tall stack muffler with the flap on top which is only 3Lbs 1-1/4 ounces. It should last forever now. Is that an original style muffler for the electro? My daughters i just have a round simple muffler. Share this post Link to post Share on other sites
formariz 12,358 #28 Posted September 10, 2020 (edited) The small round muffler is the original type to it I am sure. I now have finished "plumbing" muffler pipe under foot rest coming out of rest's back. photo is earlier version of "plumbing", it now goes directly under foot rest.Very happy with the way it works and sounds. Edited September 10, 2020 by formariz 1 1 Share this post Link to post Share on other sites
fourcarp 0 #29 Posted May 31, 2023 I live in Grand Rapids with a C-120. Would you have a muffler that would fit ? Share this post Link to post Share on other sites
jay bee 915 #30 Posted June 2, 2023 @fourcarp I will pm you. Share this post Link to post Share on other sites
jenniferliveson80 0 #31 Posted July 15, 2023 Do you have/ or can make a muffler for a C-160 wheel horse garden tractor?? Share this post Link to post Share on other sites
jay bee 915 #32 Posted July 17, 2023 Sorry @jenniferliveson80 I am no longer having them made for me. The tariffs that were put on steel and aluminized steel in March of 2018 raised the cost beyond what I felt was reasonable. These crossed the border twice, once as raw product and again as finished product so they were taxed two times. When we had them, they sold for $125 on Red Square and about $150 on E-bay. They would fit any of the Kohler single cylinder engines and also the Tecumseh singles and were adaptable enough to be used on other engines with a little owner ingenuity. Thanks for your interest and good luck with the C-160. Those are on many members bucket list. Share this post Link to post Share on other sites
Ken Boyd 0 #33 Posted December 19, 2024 Where can I buy one? Share this post Link to post Share on other sites
953 nut 64,576 #34 Posted December 20, 2024 18 hours ago, Ken Boyd said: Where can I buy one? You have responded to a very old post. If you want up to date answerer to any question you should start a new post of your own. Click on this link then click on "Start a New Topic" and ask your questions. https://www.wheelhorseforum.com/forum/3-wheel-horse-tractors/ Share this post Link to post Share on other sites
jay bee 915 #35 Posted December 20, 2024 @Ken Boyd refer to post #32 above your post. I am no longer having the made but I may have a solution for you. I’ll send you a pm. Share this post Link to post Share on other sites
artfull dodger 440 #36 Posted January 12, 2025 There is a short body muffler made for Gravely rear engine tractors that work well on the horses and have a nice tone to them. Sometimes you can save the actual pipes from the bad muffler and reweld or clamp them to the new one or fab up your own pipe off the muffler. 1 Share this post Link to post Share on other sites
