Jaymon74 84 #1 Posted February 12, 2017 In a previous thread I mentioned that I had bought a 1972 Bronco 14 to get parts off of for my 1968 Charger 12. Question is, will they interchange? I'm talking deck mainly. I'm sure the hitch and hydraulics will work fine. Is it the same transmission? Share this post Link to post Share on other sites
Ed Kennell 43,173 #2 Posted February 12, 2017 Both have the same tranny...Sundstrand 90-2046. The deck should also work, even though I believe the 68 has the side drive and the 72 has the front mule drive. You may have to connect the 68 deck directly to the rock shaft. 2 Share this post Link to post Share on other sites
Jaymon74 84 #3 Posted February 13, 2017 2 hours ago, Ed Kennell said: Both have the same tranny...Sundstrand 90-2046. The deck should also work, even though I believe the 68 has the side drive and the 72 has the front mule drive. You may have to connect the 68 deck directly to the rock shaft. Will the mule drive swap onto the 68? Share this post Link to post Share on other sites
Ed Kennell 43,173 #4 Posted February 13, 2017 You may have to drill holes to mount the front attach-a-matic, but it should work. I'm not sure, but I don't think the hood hinge would be a clearance problem. It will require a different length drive belt. 2 Share this post Link to post Share on other sites
Jaymon74 84 #5 Posted February 13, 2017 13 hours ago, Ed Kennell said: You may have to drill holes to mount the front attach-a-matic, but it should work. I'm not sure, but I don't think the hood hinge would be a clearance problem. It will require a different length drive belt. Awesome! I was hoping it would work out that way. Hopefully I'll still be able to use my snow plow with the mule drive in place. Share this post Link to post Share on other sites
82Caddy 851 #6 Posted February 13, 2017 The attach-a-matic mule drives slip right off with the push of a rod, so no need to keep in on with the blade. Plus it inhibits some lift of the blade. 2 Share this post Link to post Share on other sites
JimmyJam 542 #7 Posted February 13, 2017 (edited) Yes remove the mule-drive. Use mid attachment for the blade. I was having a similar problem with my '68 Electro 12 and trying to use parts from a '73 Automatic 12. Pre-1970's (pre-Attach-a-matic day's). The welded frame fronts, axle mounts, and hood brackets all prevent the addition of a mule drive. So for me I am having had to do alot of modifications to use Attach-a-matic attachments. Edited February 13, 2017 by JimmyJam 1 Share this post Link to post Share on other sites
Ed Kennell 43,173 #8 Posted February 13, 2017 Yeah, like Caddy said, When you remove the deck to install the dozer , remove the mule drive with the deck drive belt attached. As you will find, you must disassemble the mule drive to install the belt. 1 Share this post Link to post Share on other sites
