1995 520H+96+97 939 #101 Posted March 24, 2018 (edited) 3/24/2018. Change over, 1997 520H. 46 degrees. 105 hrs. Edited March 25, 2018 by 1995 520H+96+97 3 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #102 Posted March 24, 2018 Man that '97 sure is sweet . 3 Share this post Link to post Share on other sites
1995 520H+96+97 939 #103 Posted March 24, 2018 22 minutes ago, WVHillbilly520H said: Man that '97 sure is sweet . Sweet Spare. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #104 Posted March 24, 2018 Started snowing. Share this post Link to post Share on other sites
1995 520H+96+97 939 #105 Posted April 13, 2018 4-13-2018. Change over 1995 520H. 1145 hrs. 4 Share this post Link to post Share on other sites
1995 520H+96+97 939 #106 Posted April 18, 2018 (edited) 4/18/2018. 35 degrees, 11:00 AM. 42 degrees. another load. Edited April 18, 2018 by 1995 520H+96+97 4 Share this post Link to post Share on other sites
1995 520H+96+97 939 #107 Posted April 18, 2018 4/18/2018. 44 degrees, third load firewood. Share this post Link to post Share on other sites
Ed Kennell 46,203 #108 Posted April 18, 2018 Man that makes a lot of sawdust when you saw the chunks. If you were closer, i'd bring this. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #109 Posted April 19, 2018 (edited) 4/19/2018. 42 degrees. 1st load. 2nd load firewood. 49 degrees. Edited April 19, 2018 by 1995 520H+96+97 Share this post Link to post Share on other sites
1995 520H+96+97 939 #110 Posted April 21, 2018 4/21/2018. 40 degrees, breezy. 1st load. 1 Share this post Link to post Share on other sites
Ed Kennell 46,203 #111 Posted April 21, 2018 Looks like each load gets stacked a little higher. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #112 Posted April 21, 2018 57 minutes ago, Ed Kennell said: Looks like each load gets stacked a little higher. Ground is drying, load em heavy. 4/21/2018. 48 degrees, breezy. 2nd load. 2 Share this post Link to post Share on other sites
1995 520H+96+97 939 #113 Posted April 22, 2018 4/22/2018. 3 PM, 60 degrees, breezy. Snow should be gone this week. 2 Share this post Link to post Share on other sites
1995 520H+96+97 939 #114 Posted May 6, 2018 (edited) 5/6/2018. First mow of 2018. 1 3/4 gallon gas. Start hrs. 1149.5, ending hrs. 1150.5. Edited May 6, 2018 by 1995 520H+96+97 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #115 Posted May 16, 2018 5/16/2018. 33 degrees 6 AM, 42 at 9 AM. Couple of trees leaning towards road, power lines, 520H to light to pull. Ferguson TE-20 did the job. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #116 Posted May 16, 2018 5/16/2018. 11:20 AM ,57 degrees. Cut, loaded, another leaner. 1 Share this post Link to post Share on other sites
peter lena 9,901 #117 Posted May 16, 2018 where I live in Connecticut, ever source handles power, and do a terrible job at it, glairing tree and maintenance issues are ignored .talking to line repair people , they fear termination over job/work ideas. crushing management mentality. you are smart to keep after area, good luck , pete 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #118 Posted June 16, 2018 6/16/2018. 7:50 AM,58 degrees, 1 gallon gas, 1159.6 hrs now. Been mowing once a week. Share this post Link to post Share on other sites
1995 520H+96+97 939 #119 Posted June 23, 2018 6/23/2018. 7:45 AM, 58 degrees. shared mowing duty 1995 with the 1997 520H. 1 1/4 gallon gas. 1 Share this post Link to post Share on other sites
lynnmor 8,847 #120 Posted June 23, 2018 A couple of comments. I would think that the bungee cord is rather hard on the plastic bushings in PTO lever. I have been keeping the deck belt covers on for the past 18 years, my left foot is still numb from the serious damage. I see you added a wear surface on the upright piece on the deck, I added nylon pieces there as well and they are holding up after many years, steel on steel wears rapidly. Do you have a source for the caps on the front spindles? 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #121 Posted October 13, 2018 10/13/2018. 3:30 PM, 47 degrees. Change over the 1995 Toro 520H. 1181 HRS now. Mowed every Saturday, 1 gallon of gas every mow, belts look OK, bearings quiet. Sharpened blades. 1 quart motor oil for the summer season, 31 hrs. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #122 Posted October 14, 2018 10/14/2018. 12:30 PM, 51 Degrees, Breezy. Mowed and change over, 1997 Toro 520H. 108.3 HRS now. 3/4 gallon gas. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #123 Posted November 13, 2018 12:15 PM to 1:00 PM snowblow 4" heavy snow with 1996 520H 768 hrs. 1/2 gallon gas, 85 degrees in cab. Still snowing, suppose to change over to rain. 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #124 Posted November 17, 2018 6:15 AM to 7:45 Am.19 degrees, slight breeze. Snowblow 5" dry, fine snow with 1996 520H and scrape with 1995 520H. 1 gallon gas, 86 degrees in cab. 1 Share this post Link to post Share on other sites
Daron1965 644 #125 Posted November 17, 2018 I really like your set up. You have the best of both needs covered. 1 Share this post Link to post Share on other sites
