Thegearhead0324 1,352 #1 Posted February 8, 2017 Hello all. Today it was ok enough outside to go out in the shed and replace one of the many things I bought from fleabay. I decided to replace the head gasket, (all original, never taken off.) I was really nervous, but surprisingly all 9 bolts came right off no problem. Also, I've definately seen worse. For 50 years old, this thing really surprised me. I also replaced the front breather cover filter and gaskets. Here's a couple before and after pics. 4 Share this post Link to post Share on other sites
Ed Kennell 42,081 #2 Posted February 8, 2017 Looks good....what did you use to clean it? Share this post Link to post Share on other sites
953 nut 60,160 #3 Posted February 8, 2017 Remember to redo the torque on the head bolts after it has run for an hour or so. 2 Share this post Link to post Share on other sites
Thegearhead0324 1,352 #4 Posted February 8, 2017 A soft wire wheel on a cordless drill, brake cleaner, and a microfiber cloth. Used the kohler manual for torque spec and sequence. I really thought those bolts would give me a hard time I was prepared for the worse, but it was literally like butter. Will do, that actually slipped my mind about the retorque lol. I got the carb off and few other things too that I gotta take care of. 2 Share this post Link to post Share on other sites
midpack 1,011 #5 Posted February 9, 2017 did you check the head for flatness? I have a K341 that I'm getting ready in case my series I KT17 bites the dust the head was so far out I ended up milling it flat, then doing the 180 grit sandpaper on a surface plate thing to make sure it was flat sometimes it's good to have a machine shop at your disposal! 1 Share this post Link to post Share on other sites
Ed Kennell 42,081 #6 Posted February 9, 2017 I just decarbed my K-321. It took about an hour of polishing on a piece of 1/2" thick glass to get the head back to flat. Share this post Link to post Share on other sites
Thegearhead0324 1,352 #7 Posted February 9, 2017 I checked the head and block were perfect. As for carbon build up... most of it wiped off there was nothing hardened. I guess I was really lucky lol. 1 Share this post Link to post Share on other sites
