Duramax7man7 506 #1 Posted February 3, 2017 (edited) How Often should I flush the oil in this unit? Once a year? Edited February 3, 2017 by Mastiffman Share this post Link to post Share on other sites
KC9KAS 4,745 #2 Posted February 3, 2017 As long as the rubber shift boot is in good shape and no dirt or water gets into the tranny, I doubt you need to flush it at all. Again, as long as the axle seals do not leak, you won't have to add lube either, but do check the level of the lube. 4 Share this post Link to post Share on other sites
953 nut 63,617 #3 Posted February 3, 2017 Your owner manual will tell you the same thing. 2 Share this post Link to post Share on other sites
rmaynard 16,782 #4 Posted February 3, 2017 I have a 1977 B-100 8-speed. The transmission oil was changed when I bought it in 1993, and it has only been changed once since then. I've replaced the shifter boot several times. As an interesting side note, in all that time, I have never had a leaky seal. 1 Share this post Link to post Share on other sites
Rob R 978 #5 Posted February 3, 2017 My take on this is simple once a year take a look at the color and fill level of the oil.... if black add to the fill and leave it alone, if gray or brown definitely drain flush and replace. What kills the seals is when the oil is contaminated with water (bad boot seal or condensation). THATS ALL THERE IS FOLKS..... 4 Share this post Link to post Share on other sites
Duramax7man7 506 #6 Posted February 3, 2017 It didn't come with a manual. But I assume I can download one from the site... ? Awesome, thanks for all the tips fellas! 2 Share this post Link to post Share on other sites
Racinbob 12,510 #7 Posted February 3, 2017 Yup. Just go to the manuals section. I didn't link to it because I don't know what tractor you have. You'll want the owners manual and there's a dandy service manual as well. 1 Share this post Link to post Share on other sites
Duramax7man7 506 #8 Posted February 3, 2017 (edited) 1. 1995 312-8 #73362 and... 2. 1990 520h #41-20OE01 Edited February 3, 2017 by Mastiffman Share this post Link to post Share on other sites
Racinbob 12,510 #9 Posted February 3, 2017 Here ya go 1 Share this post Link to post Share on other sites
rmaynard 16,782 #10 Posted February 3, 2017 You know, I'm going to correct my previous statement on only one oil change since 1993. One winter, I left the tractor uncovered all winter. In the spring I noticed that the shifter boot was cracked. So, knowing that oil rises to the top and water settles to the bottom, and also knowing that the tractor had not been started or moved all winter, I removed the drain plug and drained about a 1/2 pint of water from the bottom of the transmission. It wasn't until several years later that I drained, flushed, and refilled it with new. 1 Share this post Link to post Share on other sites
pfrederi 19,511 #11 Posted February 3, 2017 My L107 gets new rearend oil every 10-15 years...needed or not. Still works great...and I am still using 40wt motor oil as originally specified. Share this post Link to post Share on other sites
Duramax7man7 506 #12 Posted February 3, 2017 18 minutes ago, Racinbob said: Here ya go NICE! Thank you! Very Helpful! 6 minutes ago, rmaynard said: You know, I'm going to correct my previous statement on only one oil change since 1993. One winter, I left the tractor uncovered all winter. In the spring I noticed that the shifter boot was cracked. So, knowing that oil rises to the top and water settles to the bottom, and also knowing that the tractor had not been started or moved all winter, I removed the drain plug and drained about a 1/2 pint of water from the bottom of the transmission. It wasn't until several years later that I drained, flushed, and refilled it with new. Oh man.... YIKES! Good idea changing it then. 5 minutes ago, pfrederi said: My L107 gets new rearend oil every 10-15 years...needed or not. Still works great...and I am still using 40wt motor oil as originally specified. So the older models called for 40wt and newer models call for 90wt? Did I read that correctly somewhere? Okay, question answered with that manual as there are different T ratings for Trans oil... ha ha. Share this post Link to post Share on other sites
Duramax7man7 506 #13 Posted February 3, 2017 And my 520h Manual! Nice! 41-20OE01... Is this correct? Onan & Toro power plus (20.0 -12.5hp, 400, 500, 600, 700- series) Above 80*F = SAE 50w Above 60*F = SAE 40w 32*F - 100*F =SAE 30w Below 32*F = 20w-30, SAE 10w, 5w-30 Below 20*F = 5W-20 Share this post Link to post Share on other sites
dcrage 631 #14 Posted February 3, 2017 Just to add to the earlier posts: My 310-8 was purchased new in 1991 and I have yet to change or add any fluids to the rear end. I do check the levels regularly. 1 Share this post Link to post Share on other sites
bmsgaffer 2,069 #15 Posted February 3, 2017 Just to add to this, my C-105 has been stored inside since 1988, and has not had an oil change (or a new drive belt) since then (to be fair, its been out of service since 2010 or so? and it will get a full on flush and change when I get back to it) 1 Share this post Link to post Share on other sites
