redhead 10 #1 Posted January 19, 2017 Ho w do you know if you have a Kohler or Walbro Carb on old B-100 ? No name just 2 numbers-------1 on flange and 1 under where intlet gas supply line is any help woud be appreciated i nee a rebuild kit for carb THANKS Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,719 #2 Posted January 19, 2017 Can't help with the ID unless it is in this manual. You may go through the whole manual before you find your numbers. In printed format it makes more sense as there are left and right pages open at the same time. You should be able to figure it out but hollar if you can't. According to the parts lists the 1974-1976 B-100 used carb # A-237772 and 1977 used carb # 47 053 13. Garry 3 Share this post Link to post Share on other sites
953 nut 62,116 #3 Posted January 19, 2017 Give these a try, the Brian Miller web site is loaded with great information. Carburetor throttle shaft bushing from Brian Miller.docx Carburator adjustments.docx 3 Share this post Link to post Share on other sites
gt4 196 #4 Posted February 1, 2017 Hey 953nut, those links were very,very helpful. Thanks very much for posting those👌 1 Share this post Link to post Share on other sites
