Notfishin 64 #1 Posted January 12, 2017 Guys i seen a 312A with a louvered hood . with that hood fit all the 300 series tractors . Share this post Link to post Share on other sites
Notfishin 64 #2 Posted January 12, 2017 what im asking is can the riser on the dash be installed on the 300 series to make this hood work. Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted January 12, 2017 I believe it will fit. 1 Share this post Link to post Share on other sites
Notfishin 64 #4 Posted January 12, 2017 found a 312A for Parts , and i like the way the hood looks , before i bought this and drive to go pick it up .was just woundering if it would even work or if anyone had installed one before . Share this post Link to post Share on other sites
JAinVA 4,638 #5 Posted January 12, 2017 (edited) I have a 312a hood and a 310-8 hood in the shed sitting next to each other.With the exception of the louvers they are the same.In the 300-400-500 world only the 500 series has a different dash hump.The 500 hood is also wider in the rear area than the 3-400 series.JAinVA Edited January 12, 2017 by JAinVA 2 Share this post Link to post Share on other sites
Notfishin 64 #6 Posted January 12, 2017 Great was hoping that was the way it was.only time I had seen the louvers was on the 500 series .didn't even know they did it on 300 series.was this after 95 ? Share this post Link to post Share on other sites
shallowwatersailor 3,222 #7 Posted January 12, 2017 (edited) The 312A with the louvered hood was sold from 1985 to 1987. The '85 and '86 share model numbers. The '87 has its own model number so could be different. The 417A also has the louvered hood. Edited January 12, 2017 by shallowwatersailor 3 Share this post Link to post Share on other sites
JAinVA 4,638 #8 Posted January 12, 2017 Notfishin, Just so you can see how much wider the 520 hood is at the rear than a 300-400 hood look below.The 518 hood is the only one I'm aware of that has no louvers. 1 Share this post Link to post Share on other sites
Jerry77 1,218 #9 Posted January 12, 2017 1 hour ago, JAinVA said: Notfishin, The 518 hood is the only one I'm aware of that has no louvers. 516 don't either..... Share this post Link to post Share on other sites
JAinVA 4,638 #10 Posted January 12, 2017 I stand corrected. Share this post Link to post Share on other sites
Notfishin 64 #11 Posted January 13, 2017 Guys thanks for the info. Allways learn something from this group. 1 Share this post Link to post Share on other sites
