hbryant123 7 #1 Posted January 10, 2017 today i bought a wheel horse b111 at th scrap yard! 75$ I thought it was kinda neat, it was almost all complete minus the ignition switch and fuel tank! it has the 4 speed trans i believe, original stickers, i think it has an 11 hp briggs, which wasnt locked up. So is this tractor at all valuable, was it any good? reliable? How hard is it to get a key switch? thanks! 4 Share this post Link to post Share on other sites
Ed Kennell 46,244 #2 Posted January 10, 2017 to the . The first step in assessing your tractor is to print out the manuals that you will find in the manuals section. Switches are readily available, but they are different, so you need to ID your tractor and check the wiring diagram. If you need help, It is best to post some pictures of the tractor and hopefully a ID plate with readable numbers. This will help the moderators find the correct link to the proper manuals. As far as the value of the tractor, you answered that .... $75. 3 Share this post Link to post Share on other sites
SylvanLakeWH 31,559 #3 Posted January 10, 2017 Nice Score on the tractor! Share this post Link to post Share on other sites
953 nut 66,695 #4 Posted January 10, 2017 This manual will get you started on your quest to revive your . Share this post Link to post Share on other sites
hbryant123 7 #5 Posted January 10, 2017 Thanks Everyone! I will uploads some pics asap! 1 Share this post Link to post Share on other sites
hbryant123 7 #6 Posted January 10, 2017 I made a jumper wire for the ignition switch plug and after checking spark it had a it running on start fluid, no smoke, no knocking or odd sounds ! The carb bowl was clean! 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,283 #7 Posted January 10, 2017 May be of some help Garry Share this post Link to post Share on other sites
Jakeshorsetuff 36 #8 Posted January 11, 2017 I have a couple of wheel horses and I get all my manuals at www.Mywheelhorse.com they should have the manual for a b111. 22 hours ago, hbryant123 said: 22 hours ago, hbryant123 said: Share this post Link to post Share on other sites
hbryant123 7 #9 Posted January 11, 2017 (edited) Thanks Everyone for the Manuals! and Info! looks like what i have is the 4 speed peerless 669 transmission! with the engine idling in neutral it seemed like there was some thumping under the tractor, i am thinking it is a bend spot in the belt from sitting?? I am trying to find the eng to deck belt size, after searching the manuals and forum i came up with 1/2 inch by 40 inch for the three blade rear discharge deck, does this sound right? The electric pto enguage when i moved the lever, i wanna see if it will turn the deck after i inspect and grease it! As for a fuel tank any suggestions on where to get one that will be original or close? How strong is the peerless 669 transmission? what can i do to make it last, this mower will be for mowing only most likely! Edited January 11, 2017 by hbryant123 forgot to add! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,283 #10 Posted January 11, 2017 Here are the decks I see for the B-111 4-speed and there may be more. Notice the width of cut and the R and S for side or rear discharge is in the model number. Garry Share this post Link to post Share on other sites
hbryant123 7 #11 Posted January 11, 2017 Thanks! i found mine is the 42 inch rear discharge deck! taks the 1/2 by 41 belt! The next question i have is how is the belt tensioned? Share this post Link to post Share on other sites
Jakeshorsetuff 36 #12 Posted January 12, 2017 About the gas tank check eBay ,mower part pros they are a little over priced and partstree.com. I'm not too familiar with b111 so I can't tell you how the belt is tensioned. Share this post Link to post Share on other sites
hbryant123 7 #13 Posted January 15, 2017 Good news! Got new belts for the b111! I am having a hard time with the drive belt that goes from the engine to transmission. What's the best way to remove it? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,283 #14 Posted January 15, 2017 Belt replacement is covered in Section 5 of the service manual. Garry Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #15 Posted January 15, 2017 On 1/9/2017 at 8:25 PM, hbryant123 said: today i bought a wheel horse b111 at th scrap yard! 75$ I thought it was kinda neat, it was almost all complete minus the ignition switch and fuel tank! it has the 4 speed trans i believe, original stickers, i think it has an 11 hp briggs, which wasnt locked up. So is this tractor at all valuable, was it any good? reliable? How hard is it to get a key switch? thanks! what part of indiana are you from? Share this post Link to post Share on other sites
