Duramax7man7 506 #1 Posted December 24, 2016 Is this used blade worth the $75 asking price? Maybe get them down another $10- $15 make it worth it? My 42" is beat up!? I should be able to mount this right to the frame, no? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #2 Posted December 24, 2016 Don't see a 60" blade but the D-250 10-Speed models used one advertised as 59". Copy and paste this with the quotes into the search box and then select Files. "Blade Dozer 59in" Garry 1 Share this post Link to post Share on other sites
squonk 44,686 #3 Posted December 24, 2016 (edited) What tractor are you going to hook it to? The bigger the blade and it's more power and weight needed to push and lift it. Edited December 24, 2016 by squonk 1 Share this post Link to post Share on other sites
daveoman1966 3,880 #4 Posted December 24, 2016 It is, after all, only money...so................................. .buy it. Share this post Link to post Share on other sites
Duramax7man7 506 #5 Posted December 24, 2016 2 hours ago, squonk said: What tractor are you going to hook it to? The bigger the blade and it's more power and weight needed to push and lift it. I was going to hook it up to my 312-8 with 105lbs of wheel weights and chains... We don't get a ton of Snow so its not like I would be moving a ft worth at a time. 1 hour ago, daveoman1966 said: It is, after all, only money...so................................. .buy it. Not 100% sure how to take this.. ha ha. Share this post Link to post Share on other sites
Ed Kennell 43,177 #6 Posted December 24, 2016 It doesn't look WH to me. Looks like the PO altered it to fit his frame. If you can weld, you could do the same. Share this post Link to post Share on other sites
Duramax7man7 506 #7 Posted December 24, 2016 Yeah I wondered about the way that it was really rippled in the blade in comparison to other WH blades I've seen. You can almost bet that this is a 59" blade but they marked it 60" to sell it. Yeah I wondered about the way that it was really rippled in the blade in comparison to other WH blades I've seen. You can almost bet that this is a 59" blade but they marked it 60" to sell it. Share this post Link to post Share on other sites
