ti-jean 45 #1 Posted December 18, 2016 Hi after blowing snow today ..I look under the tractor and a spring was hunging, it was the lift rod assist spring it was attache to the lift rod i cant not figure where is suppose to attache my blower is 0644sc01 thank for help help Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #2 Posted December 18, 2016 Manuals help? Garry 1 Share this post Link to post Share on other sites
pfrederi 21,231 #3 Posted December 18, 2016 It hooks over the 3/4" shaft that the brake clutch work on 1 Share this post Link to post Share on other sites
ti-jean 45 #4 Posted December 18, 2016 (edited) thank Garry I already have that manual the problem all the pics are dark it is hard to see where that spring gos I se on the lift rod ok but at the front very difficult .and to front hand is break any pics of that piece thank Edited December 18, 2016 by ti-jean Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #5 Posted December 19, 2016 This later one may be better. The model number changed but the product is likely the same. Garry Good drawing on page 8. Hope it is the same. 1 Share this post Link to post Share on other sites
pfrederi 21,231 #6 Posted December 19, 2016 Sorry I was wrong I didn't notice you had a 2 Stage blower. Share this post Link to post Share on other sites
ti-jean 45 #7 Posted December 19, 2016 (edited) Wow ! this manual is greater then the one I got ...no problem I think the attachement are the same thank Edited December 19, 2016 by ti-jean Share this post Link to post Share on other sites
wallfish 20,691 #8 Posted December 19, 2016 The lift spring on my 2 stage doesn't connect to the lift rod. It connects from the blower frame up to a rod at the Tach a matic area on the PTO side. Mine is a hydraulic lift tractor so could be something else for a manual lift. There are only 2 springs on mine. That lift spring and the belt tension spring. 1 Share this post Link to post Share on other sites
ti-jean 45 #9 Posted December 19, 2016 (edited) Ok Wow ! this manual is greater then the one I got ...Oh I se I think the attachment are the same as a two stage blower thank Edited December 19, 2016 by ti-jean Share this post Link to post Share on other sites
