RAIDER 14 7 #1 Posted December 16, 2016 (edited) Kohler engine was running then it just died got gas to carb check spark plug good spark spray some gas into carb still wont run Edited December 16, 2016 by RAIDER 14 more info Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted December 16, 2016 Pull the spark plug and see if you have compression. If not, you may have broken a rod or piston let go. Share this post Link to post Share on other sites
RAIDER 14 7 #3 Posted December 16, 2016 i have compression i have compression update rechecked spark plug no spark Share this post Link to post Share on other sites
woodchuckfarmer 333 #4 Posted December 16, 2016 Try a new plug , it would be a cheep fix. Wayne 1 Share this post Link to post Share on other sites
thehappyhippy 0 #5 Posted December 17, 2016 And if that don't work you better just give her to me Share this post Link to post Share on other sites
RAIDER 14 7 #6 Posted December 17, 2016 lol naa got 2 much time in the raider 14 meter out spark plug with ignition on i was getting 12 volt on the center of plug and the outside of spark plug where it screw into motor heading to store and get a new spark plug thanks for all your help 1 Share this post Link to post Share on other sites
953 nut 63,911 #7 Posted December 17, 2016 Hope the new plug will do the trick, if not please check back and we will get that back in action. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted December 17, 2016 @RAIDER 14 I have a GT-14 that would just die, dead in its tracks....The wire on the coil was a "spade" type connection and it was loose and would fall off. A little squeeze with the needle nose and all was well. 1 Share this post Link to post Share on other sites
RAIDER 14 7 #9 Posted December 17, 2016 replaced spark plug Raider 14 runs great thank everyone for your suggestions 1 Share this post Link to post Share on other sites
woodchuckfarmer 333 #10 Posted December 17, 2016 Good deal Wayne Share this post Link to post Share on other sites
