kennethdizeo 4 #1 Posted December 11, 2016 my headlights & tail lights not working...is their a common fix ? thanks...kenny Share this post Link to post Share on other sites
benji756 341 #2 Posted December 11, 2016 is your switch good? try a jumper wire on the switch lugs Share this post Link to post Share on other sites
Hacksawhero123 351 #3 Posted December 11, 2016 If you have a test light, start at the lamp sockets and work your way back to the switch. If you replace the switch, mark the wires as to which pole they come off of (poles are identified by letters). My replacement switch had a different pole arrangement and I didn't realize it until my battery was dead because the charge wire was on the wrong pole. Mark. 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,128 #4 Posted December 11, 2016 Check every connection and fuse first. Then trace the wire all the way looking for frayed spots. Finally, check ground. Ask me how I know...I had: Bad connections, frayed / pinched wire, and intermittent ground - A Trifecta! Share this post Link to post Share on other sites
varosd 1,185 #5 Posted December 11, 2016 Which model Wheel Horse do you have? Share this post Link to post Share on other sites
