jonepeer 2 #1 Posted December 8, 2016 I have an 89 520H and im needing to know what model # snow plow is for this tractor Share this post Link to post Share on other sites
Ed Kennell 42,142 #2 Posted December 8, 2016 (edited) Page 3 of the 520H manual lists #06-48BC01 as the correct plow for this tractor. There are others that should fit. Edited December 8, 2016 by Ed Kennell Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,519 #3 Posted December 8, 2016 Blades prior to this one were 42" which is a little narrow for your tractor. Blades that followed this one for the 300, 400 and 500-Series tractors will all fit except those for the 5xi models. Look for a 06-48BC02, 06-48BC03, 79350 or 79364 This last blade requires this kit but I doubt it is absolutely necessary. Make sure you get the rear axle quick hitch required to hook it up plus the lift link. The parts list illustrates everything required. Garry Share this post Link to post Share on other sites
jonepeer 2 #4 Posted December 8, 2016 I have the opportunity to get a model #79235 but I need to know for sure if it will fit and work properly. I'm new to wheel horse and not sure about this. Way to many miles to travel and several dollar's to take a chance on something that may not work for me. Share this post Link to post Share on other sites
doc724 925 #5 Posted December 8, 2016 I think you mean 79253. That blade is not designed for the classic tractor (like the 520). Continue to look around for the correct blade. They are out there. Garry has given you the correct search info for blades to fit your machine Share this post Link to post Share on other sites
jonepeer 2 #6 Posted December 8, 2016 Thank you And it's very possible that I have numbers jumbled Share this post Link to post Share on other sites
obone 142 #7 Posted December 8, 2016 This has helped me find which attachment works with which tractor. 2 Share this post Link to post Share on other sites
