moe1965 774 #1 Posted December 6, 2016 (edited) This will be my first year using a tractor powered snowblower . it's a wheel horse raider 10. my question is how important is it to use rear weights for traction. I have a asphalt drive don't get many drifts and a heavy snow fall would be about 8 to 10 inches around here. it has turf tires on it as well. thanks in advance. happy plowing Edited December 6, 2016 by moe1965 Share this post Link to post Share on other sites
Ed Kennell 47,026 #2 Posted December 6, 2016 Weight on the rear is almost a must when using a blower. The additional cantilevered weight of the blower makes the tractor light on the rear tires. This can be a real problem if you have to back up an incline. I am sure others will offer advice on the best way to add weight as it is a very popular topic. IMO, the best is to fill the tires with window washer fluid, second best add wheel weights, and thirdly add weight in a properly designed rear weight rack. On my blower and plow machine, I do all three as I clear many steep driveways and I cannot afford to have any spinning chained wheels. I have had great success with the rubber chains. 3 Share this post Link to post Share on other sites
Lagersolut 802 #3 Posted December 6, 2016 I use wheel weights and hang suite case weights ( about 130 lbs ) off the rack for the grass bags with v bar chains - my D way is somewhat steep so going down isn't the problem....backing up and getting back up is . 3 Share this post Link to post Share on other sites
shallowwatersailor 3,221 #4 Posted December 6, 2016 (edited) Ed spelled it out very well. There is one thing to take into consideration with loading the tires with fluid. If you use that same tractor for mowing the additional weight will compress the turf. Edited December 6, 2016 by shallowwatersailor 3 Share this post Link to post Share on other sites
cod 136 #5 Posted December 6, 2016 I'll second the above posts. I filled my turf tires with water/antifreeze and even with the extra weight, if I don't put the chains on, there's no traction. Also if your driveway is higher than the lawn, try not to drop the front tires off the edge of your driveway as the weight of the blower can make it difficult to get them back up. Good luck - Cod Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #6 Posted December 6, 2016 Kinda like this, fluild filled AG tires with chains,75# cast iron weights, 120+ # suitcase weights and a cab,Jeff. 3 Share this post Link to post Share on other sites
Ed Kennell 47,026 #7 Posted December 7, 2016 All weighted down and chained up. Only a 2" snow on Valentines day but Climbing a steep driveway. 3 Share this post Link to post Share on other sites
moe1965 774 #8 Posted December 7, 2016 (edited) Thanks for all info I think the easiest thing for me the try would add weight to the back. I added a hitch on the back that I can easily make a bracket or a basket to add weight to. I work outside every day and repair water mains all winter long and really don't look forward to winter but this year is an exception. looking forward to trying it out.... Edited December 7, 2016 by moe1965 2 Share this post Link to post Share on other sites
Kurt-NEPA 756 #9 Posted December 7, 2016 I would suggest chains and wheel weights (or loaded tires). But if you have a hitch may my solution will work 2 Share this post Link to post Share on other sites
