briankd 819 #1 Posted November 30, 2016 starting to get some of my supplies together to restore my C-120.the p.o. had this tractor had an automotive style battery in it but removed it before I bought it. i cut the ends off and put smaller ring term. on them and a standard lawn and garden battery in it and the battery tray way to big for one of them. it is the original factory battery tray my battery out of my 857 fits tight in it but too small for this one. that being said did WH have some other than lawn and garden battery they used? talked to the battery guy at work he only seen them automotive style in the big zero turns and they run about 80 bucks. I'm not paying that. my thought was make a block of wood put behind battery make it fit snug then it wouldn't bee seen being behind battery Share this post Link to post Share on other sites
Achto 29,351 #2 Posted December 1, 2016 1 hour ago, briankd said: I'm not paying that. my thought was make a block of wood put behind battery make it fit snug then it wouldn't bee seen being behind battery A lot of tractors with 10hp and above engines came with an automotive battery. I have also saw a quite a few of those changed over to a lawn & garden tractor battery, so your idea would work just fine. Wal Mart has started carrying a line of auto batteries that are in the $50 range in my area. I have no idea on the quality of these batteries though. Share this post Link to post Share on other sites
wallfish 18,053 #3 Posted December 1, 2016 8 minutes ago, achto said: A lot of tractors with 10hp and above engines came with an automotive battery. Which ones? I don't recall seeing this. 1 Share this post Link to post Share on other sites
pacer 3,177 #4 Posted December 1, 2016 A lawn & garden type will work just fine in it - as you said it will probably take a 'shim' to get it snug. I use the wally world ones - about $30. Ive got one in a D-180 (which originally came with an automotive type) and its going into its 4th year. Share this post Link to post Share on other sites
Achto 29,351 #5 Posted December 1, 2016 (edited) 20 minutes ago, wallfish said: Which ones? I don't recall seeing this. My 1076 and my Raider 12 have auto style batteries with a larger tray. My 867 has a LG type battery with a smaller tray. I've observed a fair amount of tractors 10hp and up having the larger tray for an auto type battery. Edited December 1, 2016 by achto Share this post Link to post Share on other sites
wallfish 18,053 #6 Posted December 1, 2016 I never noticed that before as most of my collection is the early stuff and bigger workers are newer400 series I've owned a few C and 300 series in the past but none with a large battery tray. Was this a late 60s early 70s thing? 1 Share this post Link to post Share on other sites
Achto 29,351 #7 Posted December 1, 2016 (edited) 20 minutes ago, wallfish said: Was this a late 60s early 70s thing? Not exactly sure. My interests lie with the older tractors so far. I haven't had much experience with any thing newer than 1970. Doing a short search this does seem to carry over to the B series also. Edited December 1, 2016 by achto Share this post Link to post Share on other sites
Racinbob 11,916 #8 Posted December 1, 2016 I'd like to see pictures of the automotive battery installed. From 1960 to the end in 2007 I've never seen one. I can't say for sure in the D series though. 1 Share this post Link to post Share on other sites
pfrederi 18,632 #10 Posted December 1, 2016 There are at least two sizes of battery box. I will measure them later. I just use some scrap wood to hold L&G batteries in the bigger boxes. Charger/Electro used the bigger box and i assume originally had an automotive style battery with top terminals. Pics ar from Electro12 manual...looks automotive to me. 2 Share this post Link to post Share on other sites
Ed Kennell 41,775 #11 Posted December 1, 2016 Yep, looks automotive, thanks Paul. Share this post Link to post Share on other sites
Racinbob 11,916 #12 Posted December 1, 2016 Excellent Paul. Is there any indication of the group size of those batteries? 1 Share this post Link to post Share on other sites
pfrederi 18,632 #13 Posted December 1, 2016 I need to go out later and measure the larger box. They look like overkill...but I have 14 year old John Deere that I bought new and it came with an Automotive style JD Battery. Still working (knock on wood)/. Never had a L&G last that long. 1 Share this post Link to post Share on other sites
pacer 3,177 #14 Posted December 1, 2016 I have 4 of the "Big D's" and all have the large tray indicating they came with auto size. My D-180 came to me in VERY original condition and had a auto side post battery with original side post cables. But, as so often happens there came a day when the 180 batt was dead and needing to do -- something? I robbed a L&G batt off a C model and kept meaning to change it back out -- just never got around to it! So now all 4 of them has a L&G type. I had to devise a different hold-down clamp to accommodate the overly large tray, but that smaller battery starts the big twins easily. Share this post Link to post Share on other sites
pfrederi 18,632 #15 Posted December 1, 2016 (edited) Charger/Electro Battery trays were 8-1/2 x 5-1/2. Newer style are about 7 x 5. Picture is a 22NF in the older bigger tray. it is 9-1/2 inches tall to top of terminal posts that would seem to clear the gas tank in my Charger and Electros. Based on that Grp 45 or 51 51R would seem to work also http://www.batteryweb.com/bci.cfm Pictures won't upload right now will try later Edited December 1, 2016 by pfrederi 3 Share this post Link to post Share on other sites
Achto 29,351 #16 Posted December 1, 2016 5 hours ago, Racinbob said: I'd like to see pictures of the automotive battery installed. From 1960 to the end in 2007 I've never seen one Here's a pic of my 1076 with an auto battery in it. 2 Share this post Link to post Share on other sites
pfrederi 18,632 #17 Posted December 1, 2016 is the negative terminal on the PTO side of the tractor? Share this post Link to post Share on other sites
Achto 29,351 #18 Posted December 1, 2016 1 minute ago, pfrederi said: is the negative terminal on the PTO side of the tractor? Yes. This tractor was really bad when I got it but was untouched as far as modifications. I did my best to put every thing back to the way it was. Share this post Link to post Share on other sites
SALTYWRIGHT 861 #19 Posted December 1, 2016 MT GT-14 HAS A GROUP 22NF AUTOMOTIVE BATTERY. RUSS Share this post Link to post Share on other sites
pfrederi 18,632 #20 Posted December 1, 2016 My second cross over between hobbies!!!! 22NF battery is from my M37 Share this post Link to post Share on other sites
Racinbob 11,916 #21 Posted December 1, 2016 With all the tractors I've had over the decades now I have to wonder if somewhere along the line I had one but I sure don't remember it. Share this post Link to post Share on other sites
briankd 819 #22 Posted December 3, 2016 (edited) On 11/30/2016 at 8:36 PM, achto said: A lot of tractors with 10hp and above engines came with an automotive battery. I have also saw a quite a few of those changed over to a lawn & garden tractor battery, so your idea would work just fine. Wal Mart has started carrying a line of auto batteries that are in the $50 range in my area. I have no idea on the quality of these batteries though. well that explains the automotive cable ends looked like factory that I cut off. got an 350 or something cc amp exide batt. in my 857 had it for 7 yrs now been good battery. thanks for the info Edited December 3, 2016 by briankd Share this post Link to post Share on other sites
Sarge 3,465 #23 Posted December 10, 2016 Those 22NF batteries were common stuff in the 60's and early 70's , not so much anymore and the prices on them are quite high.... Sarge Share this post Link to post Share on other sites
Howie 899 #24 Posted December 11, 2016 That's why i changed the battery on my 1969 Raider.when I redid it three years ago. Got a tray to fit the battery and put it in. Put in one with enough cca's to crank it. Share this post Link to post Share on other sites
pfrederi 18,632 #25 Posted December 11, 2016 (edited) If the 22NF is too pricey you could also use a Grp 51 or 55 (terminals maybe reversed on 55) Length Width height 22NF 9.4 5.5 8.9 51 9.4 5.1 8.8 55 9.5 5.5 9.0 Edited December 11, 2016 by pfrederi Share this post Link to post Share on other sites
