rwmastel 47 #1 Posted November 29, 2016 The house we are moving into next month has about a 1/2 acre lawn (just a bit much for a push mower). Never had a large lawn so I never had a riding mower or garden tractor before. I bought a 1999 314-8 w/ 48" SD mowing deck from a co-worker for the lawn. The wife wants to try gardening, which is another new thing for us. Is it worth getting a 79370 tiller attachment for a small vegetable garden? Small is defined as 10' x 10' to start with this year. If the garden is successful and she maintains the enthusiasm, I'm assume the area could double or triple next year. Advice? Share this post Link to post Share on other sites
lynnmor 8,256 #2 Posted November 29, 2016 10 x 10 is very small. If you use the tractor tiller to work the ground between rows, you would have little productive space. A small, cheap walk behind is what you want. They usually can be narrowed by removing the outboard tines, allowing them to be used as a worker between rows. If the hobby grows or you want to do major ground work, then the WH tiller might be in order. 1 Share this post Link to post Share on other sites
Digger 66 3,488 #3 Posted November 29, 2016 24 minutes ago, rwmastel said: I bought a 1999 314-8 w/ 48" SD mowing deck from a co-worker for the lawn. For a 1/2 acre lawn ???? THAT'S A W E S O M E Share this post Link to post Share on other sites
Jerry77 1,218 #4 Posted November 29, 2016 48 minutes ago, rwmastel said: Small is defined as 10' x 10' to start with this year I maintained a 1/4 acre garden for years with a walk behind 5 hp tiller --handy because you could do almost all of the cultivating with it..would have been nice to turn it with a big tiller, but it worked ok....when I moved to a smaller garden such as the one you are going to have I bought a Mantis tiller - makes a lettuce bed out of the soil, but wouldn't be good for an area much over 20 feet by 10 feet because it turns a very narrow path - great for cultivating tho....have fun Share this post Link to post Share on other sites
Ed Kennell 43,783 #5 Posted November 30, 2016 May be a Mad Max with some of the tines removed? 3 Share this post Link to post Share on other sites
pfrederi 19,267 #6 Posted December 1, 2016 I have a WH tiller on a C81 and also a 1970s vintage Troybilt rear tine tiller. The Troybilt does a much better job and is more than enough for a small garden. Also if you have to fence in your garden (as I do) the WH is too ungainly and requires too much space to maneuver. After a couple of years the garden may grow...or it may shrink (they are a lot of work). I would just rent a tiller for a day each year. 2 Share this post Link to post Share on other sites
Sarge 3,470 #7 Posted December 2, 2016 I had a 50'x110' garden for several years and finally had to give it up - just took too much of my time . A large tiller would have helped but if you plan to do potatoes or something like that they can turn the soil a bit too fine . My Mantis was by far the best investment - nice to just go down around plants and chew up any weeds starting and they do an amazing job . Wife says if we ever do it again it will be a raised bed small plot and I agree - avoids all the weeds started from blowing grass and seeds when mowing . A good heavy tiller though is seat time and if there are neighbors doing gardens can turn into a few bucks to help pay for the tiller....just saying . Sarge 2 Share this post Link to post Share on other sites
rwmastel 47 #8 Posted December 2, 2016 (edited) Great advice everyone! I guess I need to get me and the wife signed up for some gardening forums. Fence! I forgot about needing a fence. We have lots of woods to our north and a corn field to our south, so we have deer, wild turkey, rabbits, and lord knows what else. So, yes, we will probably need a fence. That alone means I should get a hand-operated tiller. Renting! I did mention that the wife might lose interest, so it make sense to rent (or borrow!) a tiller this spring to create the garden area. Operating! I assumed I would be tilling the whole garden area twice a year. In early spring to make planting easy and in early winter to add in some compost. Why till between plant rows during the summer? Sarge - We thought about raised beds, but have heard they demand LOTS of water. Digger 66 - Below are some pics of it in it's old home (in my introduction to the forum). I figured if 1/2 acre was too much for a push mower, so might as well get a riding mower / garden tractor that will get the job done fast. Also, I plan to use it for other things: - a spreader for grass health (seed, fertilizer, herbicide) - a leaf sweeper or broom (?) that flips the leaves up into a large bag - a trailer to haul things We have a 1/2 acre lawn and 1 acre of woods. Nice relaxing property to enjoy, but wanted one piece of equipment to help me do that! Edited December 2, 2016 by rwmastel 1 Share this post Link to post Share on other sites
Sarge 3,470 #9 Posted December 3, 2016 Yes , raised beds take a huge amount of water unless you mix in peat and other materials to hold moisture , it's still a good idea to build in some sort of irrigation lines to feed it occasionally . I have heard of some lining the bottom with plastic or pond liner to help keep the drainage limited , maybe an option . Critters and weeds are your two biggest issues , it also is very dependent upon what you want to grow so everything must be considered . Forums are a great resource to learn about obstacles and ways to solve them . I miss my garden ,but don't miss keeping the weeds at bay and tending 36+ tomato plants nor the 380lbs of potatoes from that last season .... Sarge Share this post Link to post Share on other sites
