limited12 360 #1 Posted November 27, 2016 (edited) I have always heard there was no cure for the wheel horse fever, i now believe Made another haul today, and looks like i might need to make a couple more later Todays pick up GT-14 with 3 point hitch, ny other two did not have this pump on the rear, can some one tell me what this was Nice unmolosted 704 all origanal Little lawn ranger with remanufactor engine C-85 rough but ok 2 short frame blades 1 rj snow plow 14 hp kohler Edited November 27, 2016 by limited12 17 Share this post Link to post Share on other sites
953 nut 67,469 #2 Posted November 27, 2016 7 minutes ago, limited12 said: pump on the rear, can some one tell me what this was Don't see a pump, but you do have an independent lift cylinder so a mower and a tiller could be mounted and operated independently. Pretty sure it is home brewed but a great idea. Nice Haul, guess I should tell everyone I am getting out of the hobby so a whole herd would follow me home. 3 Share this post Link to post Share on other sites
Pollack Pete 2,273 #3 Posted November 27, 2016 Well,you should really know by now............THERE IS NO CURE. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #4 Posted November 27, 2016 Very nice score and you still have more to pickup. You must have found a honey hole. Share this post Link to post Share on other sites
C-101plowerpower 1,606 #5 Posted November 27, 2016 1 hour ago, 953 nut said: Don't see a pump, but you do have an independent lift cylinder so a mower and a tiller could be mounted and operated independently. Pretty sure it is home brewed but a great idea. Nice Haul, guess I should tell everyone I am getting out of the hobby so a whole herd would follow me home. looks like it might have come from a d series 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted November 27, 2016 If that is a GT-14, that is the correct setup for the independent 3 point lift. I have one like it! 2 Share this post Link to post Share on other sites
Shynon 7,604 #7 Posted November 28, 2016 2 hours ago, KC9KAS said: If that is a GT-14, that is the correct setup for the independent 3 point lift. I have one like it! Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted November 28, 2016 (edited) If the GT-14 still has the mid lift cylinder AND the back 3 point lift cylinder there should be 2 lift valves. The mid mount would have been the valve to the right of the forward/reverse motion control. The "optional" 2nd cylinder valve would have had and extension to and through the left side of the tunnel. The handle would have been on the left side of the tunnel. I actually mounted mine in the tunnel to the left of the motion control lever. It is somewhat crowded there, but it is done! I have photos, but Photobucket is not cooperating right now! Edited November 28, 2016 by KC9KAS spelling 1 Share this post Link to post Share on other sites
limited12 360 #9 Posted November 28, 2016 Thanks guys 49 minutes ago, KC9KAS said: If the GT-14 still has the mid lift cylinder AND the back 3 point lift cylinder there should be 2 lift valves. The mid mount would have been the valve to the right of the forward/reverse motion control. The "optional" 2nd cylinder valve would have had and extension to and through the left side of the tunnel. The handle would have been on the left side of the tunnel. I actually mounted mine in the tunnel to the left of the motion control lever. It is somewhat crowded there, but it is done! I have photos, but Photobucket is not cooperating right now! I do have two lift valves 2 Share this post Link to post Share on other sites
Retired Wrencher 6,793 #11 Posted November 29, 2016 guess I should tell everyone I am getting out of the hobby so a whole herd would follow me home. IS THAT THE SECRET TO THIS HOBBY. limited12 Good job on the new equipment looks like a lot of great parts. 1 Share this post Link to post Share on other sites
clueless 3,427 #12 Posted November 29, 2016 When some folks fall off the wagon they fall hard, looks like you my be one. 1 Share this post Link to post Share on other sites
CasualObserver 3,416 #13 Posted November 29, 2016 1 hour ago, clueless said: When some folks fall off the wagon they fall hard, looks like you my be one. He didn't fall off that wagon, he commandeered it, kicked everyone else off and drove it over to pick up more stuff! 1 Share this post Link to post Share on other sites
