russellmc301 601 #1 Posted November 27, 2016 so my suburban is leaking on the left axle by the hub and i was wondering how i fix it and if i should. Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted November 27, 2016 Yes, you should. 1 Share this post Link to post Share on other sites
Racinbob 12,510 #3 Posted November 27, 2016 The seal is a 1257 which is now 83-2840. Availability seems to be hit and miss. No need to open it up to change it but you'll want to make sure there's no up/down, forward/back play at the bushing. If there is you'll need to replace the bushing or you'll just destroy the new seal. Replacing that will require opening it up 1 Share this post Link to post Share on other sites
russellmc301 601 #4 Posted November 27, 2016 so how would you change it? Share this post Link to post Share on other sites
Racinbob 12,510 #5 Posted November 27, 2016 Simply remove the hub and key. The seal goes around the outside of the axle. Just tap it off. Again, make sure there's no play at the bushing. Before sliding a new seal back on make sure there are no burrs on the axle that will damage the new seal and I like to put a light coat of oil on it. That picture obviously has the axle removed. You don't have to do that. 2 Share this post Link to post Share on other sites
