Pollack Pete
Anyone Ever Seen This
Pollack Pete
My 441-8 quit running a couple years ago so I parked it and used another one of my Horses to mow with.I decided to see what was wrong with the 414.No spark.Checked all wiring connections.Checked all safety switches.Cleaned spade connectors on the ignition switch.Still no spark.Pulled the fan shroud off last night and found........Head gasket had been leaking at some time and must have blew out some hot air onto the coil wire and just about burned it off.Also burned off the white primary wire on the coil.Ordered a new coil and head gasket .Hope this is all that's wrong.Funny thing is that this tractor ran perfectly until it just up and quit running.wires.jpg
Aldon
Interesting Pete.
Let us know if that resolves your issue.
Sparky
Hmmm...usually it's critter damage that kills our tractors. Never seen heat damage before.
  Mike.....
woodchuckfarmer
Check the head and see if its warped. Had a 12 hp do that and the head was warped.        Wayne
953 nut
:text-yeahthat:
