YOOPER906 13 #1 Posted November 25, 2016 Hi everybody, I added 2 18W LED lights to the tractor to see when snowblowing. When I went to test run the tractor and lights, the tractor now surges and the lights flicker when on. If the engine is off they steady burn just fine. I ran a new circuit and grounded the lights on the same post as the stock headlights. Any help??? Share this post Link to post Share on other sites
953 nut 63,075 #2 Posted November 25, 2016 Only thing that comes to mind with these symptoms is an electrical connection may have been loosened up inadvertently while you were hooking up the lights. Did you connect the lights to the existing light switch so they will operate at the same time? This manual could be helpful to you. 1 Share this post Link to post Share on other sites
