Tankman 3,523 #1 Posted November 16, 2016 Guess I'm looking in all the wrong places. Duh. Looking for parts list and owners manual for the WH 60" SD mower deck. Is the mule drive I use with my 48" SD deck the same or will I need a different mule drive? Thinking of putting one on my '90 520-8 Horse. The Horse has a forward swept axle. Any thoughts? Suggestions? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #2 Posted November 16, 2016 Start out here http://www.wheelhorseforum.com/files/ On the right side click on Mower decks and Reel (There is 593 files) Just above the 1st file there is a gray bar with the pages numbered (Up to 24) On the right side of that bar click on "Sort by". Click on "Title". Now they are sorted to an order that makes sense. Get to page 21. The easiest way to do that is go to the end (>>) and then click on page 21. That is where the 60" decks start. Garry Share this post Link to post Share on other sites
evanloock 236 #3 Posted November 17, 2016 60 inch deck uses a mule drive unique to it....so no the one for your 48 inch deck won't work without modifications. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #4 Posted November 17, 2016 Evanloock is correct. The 60" has a spring loaded pulley. I believe it was designed to allow for movement back and forth as the deck is so heavy. I ran a regular mule drive on mine and could not figure out why I kept stretching belts. Share this post Link to post Share on other sites
