redone 45 #1 Posted November 13, 2016 I am investing into a 14 hp Kohler engine, on a c105. Dose not run, but it turns over.on adverage, what are the cost of rebuilding this engine? Share this post Link to post Share on other sites
ohiofarmer 3,383 #2 Posted November 13, 2016 29 minutes ago, redone said: I am investing into a 14 hp Kohler engine, on a c105. Dose not run, but it turns over.on adverage, what are the cost of rebuilding this engine? http://isavetractors.com/internal-engine-parts/ultimate-engine-rebuild-kit/ Then you have to consider the cost of a re-bore if needed. Since I am not knowledgeable about this, I am sure that others will be along to help you evaluate whether or not you need an entire rebuild or it could be just the valves or some other issue Share this post Link to post Share on other sites
stevasaurus 23,567 #3 Posted November 13, 2016 It's about $80 + for the rebuild kit on E-Bay. http://www.ebay.com/itm/like/351889900180?vectorid=229466&lgeo=1&item=351889900180&rmvSB=true The machine shop I found will hone the cylindar , turn the crank, and grind the valves for around $100. Mine is an 8hsp K181S. Share this post Link to post Share on other sites
woodchuckfarmer 333 #4 Posted November 13, 2016 That's a good price Steve. Share this post Link to post Share on other sites
pacer 3,179 #5 Posted November 13, 2016 This is one of those questions that there just isnt any way to answer because until it is disassembled and inspected to determine what is needed. It could run from the low of what Steve mentioned, less than a hundred, to an all out rebuild that can run into multiple hundreds. To turn crank, bore, do valve seats & valves (or replace?), etc depends on small engine service that is available in your area (in my area there is little to no service of this type) Some of the shops are quite reasonable and some are not!! Another huge factor here is - do you have the ability and have the necessary tools to do a disassemble/reassemble if indeed all it needs is re-ringing? -- ring squeezer, valve seating tools, torque wrench, get the flywheel off, etc. To acquire these very necessary tools can quickly add more expense to the equation. Share this post Link to post Share on other sites
can whlvr 994 #6 Posted November 17, 2016 I'm up in Canada and it usually costs me about 500 to rebuild an engine,thats after all the goods needed,like paint,carb kit,bore,crankgrind valves,gov gear,piston rings,rod,gaskets,new air filter,spark plug,points,plunger rod,it adds up Share this post Link to post Share on other sites
FatJackDurham 318 #7 Posted November 21, 2016 On 11/16/2016 at 7:03 PM, can whlvr said: I'm up in Canada and it usually costs me about 500 to rebuild an engine,thats after all the goods needed,like paint,carb kit,bore,crankgrind valves,gov gear,piston rings,rod,gaskets,new air filter,spark plug,points,plunger rod,it adds up Under what conditions do you need to bore instead of hone a cylinder? Share this post Link to post Share on other sites
953 nut 63,916 #8 Posted November 21, 2016 If the cylinder is out of round or is worn beyond specs it will need to be bored. Select a good machine shop that you intend to use and they will measure everything for you to see what is needed. 1 Share this post Link to post Share on other sites
