Wburger86 1 #1 Posted November 13, 2016 Hi. I need help iding this snow plow please! I was given it and i cant figure out what the model is due to crappy id tag and what itll all fit.The blade is 42 inches. Thanks in Advance for any help! 1 Share this post Link to post Share on other sites
SPINJIM 1,996 #3 Posted November 13, 2016 The model number showed up better in the photo than it probably did in person. It's model number 6-7123. If you go into 'MANUALS' on this forum, and then "IMPLEMENTS', then do a search for 6-7123, you will see the info you need, including which models it fits. Welcome to Red Square . Share this post Link to post Share on other sites
AMC RULES 37,254 #5 Posted November 13, 2016 9 hours ago, SPINJIM said: The model number showed up better in the photo than it probably did in person. It's model number 6-7123. If you go into 'MANUALS' on this forum, and then "IMPLEMENTS', then do a search for 6-7123, you will see the info you need, including which models it fits. Welcome to Red Square . Share this post Link to post Share on other sites
squonk 45,593 #6 Posted November 13, 2016 I believe that plow fits the vertical shaft engine'd tractors Share this post Link to post Share on other sites
Walt 339 #7 Posted November 13, 2016 The model number shows up as 1975 model using the WH interchange pdf it shows tractors A 80 (R) and A 80 (E) as models it was for in that year. Share this post Link to post Share on other sites
