stoneman61 1 #1 Posted November 12, 2016 I have a 1989 416 with an onan engine replaced the fuel pump took the carb off and cleaned it. i still cant get it to start. i also put in 2 new spark plugs. any suggestions. I need help ! Share this post Link to post Share on other sites
SylvanLakeWH 30,449 #2 Posted November 12, 2016 Some of the Onan experts will be along shortly... Oh and... They are gonna want pics!!! 1 Share this post Link to post Share on other sites
Ed Kennell 44,624 #4 Posted November 12, 2016 The first step .. determine if you have spark . Pull the plugs and make sure they are firing when you crank the engine. If you have fire, the Onan will run if you spray fuel directly into the carb. Second step is to determine why you do not have fuel delivery to the carb. Share this post Link to post Share on other sites
Wishin4a416 2,461 #5 Posted November 12, 2016 Welcome to the forum and what Ed said. Share this post Link to post Share on other sites
HokieAg07 129 #6 Posted November 13, 2016 In my experience, and this is after having the carbs apart for cleaning, that it is easier to fill the bowl with fuel with a squirt bottle rather than relying on the fuel pump to do all that. Much less frustration trying to get it to run consistently this way rather than waiting for bowl to fill via the pump, which is engine vacuum driven. Share this post Link to post Share on other sites
rick 270 #7 Posted November 19, 2016 On 11/13/2016 at 6:26 PM, HokieAg07 said: In my experience, and this is after having the carbs apart for cleaning, that it is easier to fill the bowl with fuel with a squirt bottle rather than relying on the fuel pump to do all that. Much less frustration trying to get it to run consistently this way rather than waiting for bowl to fill via the pump, which is engine vacuum driven. Or install an electric fuel pump! Even after sitting awhile, some of the below the seat fuel tank models can grind on and on until the fuel gets to the carb. my 416H and 314-8 both have electric fuel pumps.Pull out choke, turn key on, wait until pump noise changes then start! 1 Share this post Link to post Share on other sites
entropy 104 #8 Posted November 19, 2016 This will help a great deal! Has a trouble shooting section as well. Also do a search for the demystification guide for Onan on this site. When I could not get mine running both those two guides helped me check every component of electrical system until I found the culprit. P216_P218_P220_P224_Service_965-0762S.pdf And welcome to the forum, bunch of good people here who will help if possible. Share this post Link to post Share on other sites
stoneman61 1 #9 Posted November 26, 2016 Its been a while since I was able to work on this tractor. That being said I just checked for spark and there is none. Any suggestions would be appreciated , thanks Share this post Link to post Share on other sites
WH nut 553 #10 Posted November 27, 2016 Make sure you have 12v to the + side of the coil. if not run a jumper from the battery and see if you have spark. Share this post Link to post Share on other sites
boomers_influence 106 #11 Posted November 27, 2016 stoneman please used the link to the service manual that was given by entropy. pages 8-1 and 8-2. thank you. boomer ( the used onan engine parts guy, also NOS and new ) Share this post Link to post Share on other sites
woodchuckfarmer 333 #12 Posted November 28, 2016 Is your PTO lever disengaged ? Wayne Share this post Link to post Share on other sites
