clueless 3,325 #1 Posted November 12, 2016 Bought a hand held digital tach the other day, the kind that uses reflective tape. I know the best place to put the tape is on the shaft, but with the pto clutch there's no room. Where is the second best place to put the tape. would the outer face of the pto clutch work? Share this post Link to post Share on other sites
rmaynard 16,613 #2 Posted November 12, 2016 The shaft is actually not a good place. Any part of the outer PTO bell will work, or stick it on the screen attached to the flywheel. The closer it is to the center, the less accurate it is. I have found this out from personal experience. I stick my tape on the flywheel screen, about 3" from center. 3 Share this post Link to post Share on other sites
clueless 3,325 #3 Posted November 12, 2016 Bob, what would I do without you thanks, Chris. 1 Share this post Link to post Share on other sites
lynnmor 8,130 #4 Posted November 12, 2016 If appearance is no problem, a block of bright white paint usually works. 2 Share this post Link to post Share on other sites
Wishin4a416 2,231 #5 Posted November 12, 2016 I put mine on the flywheel screen. 3 Share this post Link to post Share on other sites
