Jerry77 1,218 #1 Posted November 11, 2016 Where is the best place to buy a solenoid for my Onan P216G....part no. shows as: Part Number: 111674 Thanks guys.. Share this post Link to post Share on other sites
cleat 8,715 #2 Posted November 12, 2016 You could likely get by in this case with a simple lighting relay. Most of those are rated for between 30 and 40 amps. In the case of the Onan, that relay is only used to trigger the solenoid on the starter itself. 1 Share this post Link to post Share on other sites
953 nut 63,907 #3 Posted November 12, 2016 The solenoid is the same as used on Fords from 1956 to 1980s, any auto parts store will have them. 1 Share this post Link to post Share on other sites
cleat 8,715 #4 Posted November 12, 2016 That will definitely work. Overkill but then again more is better. I will wire in a Ford solenoid next time one of mine go south. 1 Share this post Link to post Share on other sites
benji756 342 #5 Posted November 12, 2016 probably get the ford solenoid cheaper also 1 Share this post Link to post Share on other sites
Jerry77 1,218 #6 Posted November 12, 2016 18 hours ago, 953 nut said: 18 hours ago, 953 nut said: The solenoid is the same as used on Fords from 1956 to 1980s, any auto parts store will have them FYI...Checked on ebay before going to town -- the original style ( part no 111674) is available for 11 bucks including shipping - saves having to jury rig it because it will fit in the original space...thought you all would like to know Share this post Link to post Share on other sites
boomers_influence 106 #7 Posted November 12, 2016 club MOST all of the P 216 used the solenoid shift starter. one at the 3 o clock position, the other at the 6 o clock position. there is one starter with out the attached solenoid, it would be the one able to use the FORD style remote solenoid. thank you. boomer ( the used onan engine parts guy, also NOS and new ) Share this post Link to post Share on other sites
