FrKsHwZ 15 #1 Posted November 11, 2016 Just became a SUPPORTER..! Well I feel Finally dragged it home and now trying to decide what to do with it. Definitely leaning towards parting it out or sell it all together, or keep it if the Wife say I can...lol. Idk yet. Like I said before got it all for $75. Working on the plow right now, but I did try to get the Clevis Hitch off, with no luck so far. After all that going to clean up the deck and make sure everything is lubed up " that's what she said." Well enjoy..! 6 Share this post Link to post Share on other sites
JimD 3,347 #2 Posted November 11, 2016 If you can get that engine to run this could easily be turned into a nice worker. Some pressure washing and a bit of touch up, nothing too extreme but a refresh would make her presentable. It has possibilities. 2 Share this post Link to post Share on other sites
FrKsHwZ 15 #3 Posted November 11, 2016 Unfortunately there's no compression in the engine(Tecumseh), I do have a extra running K241 generator start, was thinking about swapping it out it I did decide to keep it. 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #4 Posted November 11, 2016 9 minutes ago, FrKsHwZ said: Unfortunately there's no compression in the engine(Tecumseh), I do have a extra running K241 generator start, was thinking about swapping it out it I did decide to keep it. Pull the head..........probably just a valve stuck open.Easy fix. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #5 Posted November 11, 2016 Best of luck, and being a supporter is the best. Glenn 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #6 Posted November 12, 2016 You have come to the right place for sure! Soak that clevis while you work on other stuff. Then do it again while you work on other stuff. Then.... Share this post Link to post Share on other sites
Retired Wrencher 6,035 #7 Posted November 12, 2016 (edited) FrKsHwZ I has possibilities. In time you can get to run. Good project on the side. stick it in the shed and when you get the time work on it. You will be happy in the end. Edited November 12, 2016 by T1257 RETIRED WRENCHER. Share this post Link to post Share on other sites
CTPhil 53 #8 Posted November 17, 2016 On 11/11/2016 at 6:05 PM, FrKsHwZ said: Unfortunately there's no compression in the engine(Tecumseh), I do have a extra running K241 generator start, was thinking about swapping it out it I did decide to keep it. In the last week I'm 2 for 2 freeing hung valves in Kohlers by pouring ATF down the spark plug hole and letting them sit a couple of hours. 3 Share this post Link to post Share on other sites
