Hacksawhero123 351 #1 Posted November 10, 2016 (edited) Ok, there is no way that I'm the first guy to do this. I was looking for a replacement for my destroyed steering wheel. The options to fit the shaft were few and I thought a bit expensive. Thinking back to when I raced dirt track, I had a brain storm. Or a slight drizzle. A steering wheel quick connect is a 3/4" shaft. $25 for the quick connect and $32 for a Grant classic wheel. No modification made to the shaft. I drilled a hole in the coupler for a roll pin. I might rig a spot weld on it. Cool thing is if the wheel is in the way while doing maintenance, it takes half a second to rip it off. Mark. Edited November 10, 2016 by Hacksawhero123 Grammar 21 Share this post Link to post Share on other sites
SylvanLakeWH 32,823 #2 Posted November 10, 2016 That is slick!!! Great idea! Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted November 10, 2016 Did that to mine last summer. Have a bad leg and it makes it a lot easer to get on and off... Share this post Link to post Share on other sites
Hacksawhero123 351 #4 Posted November 10, 2016 I knew there was one of you out there that had to have this idea first. I'm not that smart 😂 Mark. 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,590 #5 Posted November 10, 2016 Mark, very ingenious. Your smarter than me. Glenn Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted November 10, 2016 My problem would be........Now where did I leave my steering wheel..... 7 Share this post Link to post Share on other sites
857 horse 2,588 #7 Posted November 10, 2016 Ive seen this idea ((and a good one too)) ......Last summmer at THE BIG SHOW,,,,,,,,,,,,,,,,,((Jay) RoadApples did this......and im not gonna discuss the Horse Head...lolol 1 Share this post Link to post Share on other sites
Jeff R. 35 #8 Posted November 10, 2016 Great idea - I like it!!! Share this post Link to post Share on other sites
Hacksawhero123 351 #9 Posted November 12, 2016 On 11/9/2016 at 9:45 PM, roadapples said: Did that to mine last summer. Have a bad leg and it makes it a lot easer to get on and off... Roadapples, you Sir are absolutely right. It is easier to mount and dismount with the wheel removed. Mark. 1 Share this post Link to post Share on other sites
Wishin4a416 2,610 #10 Posted November 13, 2016 That is a great idea! Share this post Link to post Share on other sites
USHorse 41 #11 Posted November 13, 2016 Great idea. To get the original wheel off, did you gave to cut the shaft or were you able to get the old roLL pin out? Share this post Link to post Share on other sites
Hacksawhero123 351 #12 Posted November 13, 2016 My wheel was rusted badly and bent to snot. I used an air cutoff wheel and split the wheel after drilling the roll pin. Mark Share this post Link to post Share on other sites
neil 2,416 #13 Posted November 13, 2016 What a great idea , the simple ideas are always the best Share this post Link to post Share on other sites
Texas Todd 1,026 #14 Posted November 13, 2016 Great idea! It appears that if a wheel is stuck and needs to be cut off, this would come close to replacing the cutoff length. Share this post Link to post Share on other sites
