Marv 996 #1 Posted November 6, 2016 I wound up cutting the steering shaft. Thought I would sleeve it when I put it back. Well, the shaft is worn quite badly at the dash bushing area. I have the all plastic wheel . Thinking about Drilling a hole through the wheel in line with the shaft and trying to press the shaft out. Now the question, is the wheel hub hollow above the shaft end or solid? Marvin Share this post Link to post Share on other sites
Racinbob 13,125 #2 Posted November 6, 2016 Yes, you can do that. I recently did it to this one. 2 Share this post Link to post Share on other sites
Marv 996 #3 Posted November 9, 2016 Thanks Bob. That is what I thought it would look like. Marvin Share this post Link to post Share on other sites
Retired Wrencher 6,974 #4 Posted November 10, 2016 Marvin I think you may have to press this out? My experience is that they rust solid on the shaft not easy to get off with out a press or heat. Good luck. Share this post Link to post Share on other sites
Sarge 3,473 #5 Posted November 10, 2016 It can either be pressed out or drilled out - once drilled to about 5/8" a chisel will remove it if you notch the remaining piece with a hacksaw blade - most are only 1/2" tall . Sarge Share this post Link to post Share on other sites
