hamsterwheel 2 #1 Posted November 4, 2016 (edited) Hello I am new here and also from the UK and I am looking for some advice please. I am trying to get a old Kohler k91 4hp engine to get a spark. I have bought a electronic ignition kit which is like the 'nova 2' kits you can get in America. I would like to know how do I attach the positive to the coil? Is it one of the small wires that attaches to the condenser behind the flywheel or is it the wire that attaches to the points on the outside? I have attached mine to the wire that goes to the points but I am still not getting a spark. Also there are 2 loose wires behind the flywheel that connected to the condenser that was removed. Also if we replaced the coil can anyone suggest a compatible coil or even a upgrade to a modern compatible coil for the kohler k91 4hp? The genuine or OEM coils cost way to much and we are on a tight budget. Thank you all in advance for your time and help. Edited November 4, 2016 by hamsterwheel 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted November 4, 2016 1st, Not sure on all the wring connections....sorry. Share this post Link to post Share on other sites
AMC RULES 37,254 #3 Posted November 4, 2016 Is this what you're working with? 3 Share this post Link to post Share on other sites
hamsterwheel 2 #4 Posted November 4, 2016 (edited) 36 minutes ago, AMC RULES said: Is this what you're working with? Thanks all for your welcomes Yes that is the type of kit I am using. Edited November 4, 2016 by hamsterwheel Share this post Link to post Share on other sites
Jerry77 1,218 #5 Posted November 4, 2016 1 hour ago, AMC RULES said: Is this what you're working with? Good job ! Excellent post... 1 Share this post Link to post Share on other sites
hamsterwheel 2 #6 Posted November 4, 2016 2 hours ago, hamsterwheel said: Thanks all for your welcomes Yes that is the type of kit I am using. I would like to point out I have seen that video before. That video was the inspiration for buying the kit in the first place. Share this post Link to post Share on other sites
Racinbob 12,642 #7 Posted November 4, 2016 I'm glad you started this thread hamster. I've been having intermittent spark issues with the K-91 on my Suburban. I'll get it running perfectly then it just loses spark again. I've never heard of those Nova 2 modules. I now have two of them on their way. You can find aftermarket coils for about $20. They are 'almost' a direct fit. There's a simple modification needed to make them physically fit. There's a thread on here on what needs to be done. 1 Share this post Link to post Share on other sites
hamsterwheel 2 #8 Posted November 4, 2016 No probs Racingbob. I hope it helps you out I would like to ask please when and if it does works could you pop back here and give a little tutorial on how you did it on your K91 please? Maybe include some photos (we all like pictures ) Sorry if it sounds a little cheeky Thanks 1 Share this post Link to post Share on other sites
neil 2,415 #9 Posted November 4, 2016 Welcome to Redsquare , I am also from UK , what tractor are you working on ? Share this post Link to post Share on other sites
Racinbob 12,642 #10 Posted November 4, 2016 1 hour ago, hamsterwheel said: No probs Racingbob. I hope it helps you out I would like to ask please when and if it does works could you pop back here and give a little tutorial on how you did it on your K91 please? Maybe include some photos (we all like pictures ) Sorry if it sounds a little cheeky Thanks Sure. I want to research them better first. I did a little already and it seems like the reliability may not be there. One question I haven't found the answer to is the kill switch. I don't see any reason it would be any different than with the points/condenser but I just want to verify. It will be fun playing with them in any case. At $23.99 for two of them delivered they are cheap enough. 1 Share this post Link to post Share on other sites
hamsterwheel 2 #11 Posted November 4, 2016 (edited) 58 minutes ago, neil said: Welcome to Redsquare , I am also from UK , what tractor are you working on ? Its not quite a tractor but a Howard 300/350 Rotavator/Rototiller It has a Kohler K91 4hp engine on it that has no spark and I have never worked on the kohler engines. I am more used to the horizontal Briggs 3hp/5hp engines with the nightmare pulsa-jet carbs. If I cannot get the spark working on the kohler then I am going to swap it out for a 6.5 hp Honda clone as the kohler parts are rather expensive and I am on a very tight budget. I would save the kohler engine for a later project though. 29 minutes ago, Racinbob said: Sure. I want to research them better first. I did a little already and it seems like the reliability may not be there. One question I haven't found the answer to is the kill switch. I don't see any reason it would be any different than with the points/condenser but I just want to verify. It will be fun playing with them in any case. At $23.99 for two of them delivered they are cheap enough. Thank you I would appreciated that Also I think others with the K91 would appreciate a tutorial on the upgrade to electronic ignition as it could save many old Kohler engines. I find points a pain in the neck (to put it politely) Edited November 4, 2016 by hamsterwheel Share this post Link to post Share on other sites
