Cadmandu
1" Walbro Adjustable Main Jet 47 053 86
Cadmandu
Hi All,
After removing and cleaning my carb it now backfires when I shut it off, does not start easy either and stumbles a bit.
I have the main and low idle both set at the preliminary settings.
Preliminary Settings         Main 1 1/8 now it was 1 1/4
                                         Low Idle 1 3/4 it was 2
TIA
N3PUY
Does it backfire out the muffler or carb??
Cadmandu
out the muffler
N3PUY
When you turn the ignition switch off the motor continues to suck fuel.  Just as if it was still running.
Without spark the fuel passes thru the motor out the exhaust unburned.  The muffler is hot and there the fuel ignites.
Mine has done it for ever.   When I shut it off I cover my ears especially in the shed.   It even shoots a flame a few inches out the muffler.
You can try slowing down the idle.
For the stumble open the small mixture needle.
Cadmandu
It did not backfire at the old original settings, so I might return to them.
Edited by Cadmandu
