BOBTHEBOPPER 3 #1 Posted October 28, 2016 I have many parts for the old K series kohler engines and would like to know if the 14 HP and 12 HP K series crankshafts are interchangeable. All the rod and crank journals are the same size, the stroke is the same. I am not sure if the crank and piston assembly would be out of balance using the 14 with the 12 HP piston in a 12 HP block. Thanks for any help. Share this post Link to post Share on other sites
rmaynard 16,567 #2 Posted October 28, 2016 Attached is the Kohler Crankshaft Reference Guide. That should have your answer. kohler-crankshaft-reference.pdf Share this post Link to post Share on other sites
oliver2-44 10,976 #3 Posted October 28, 2016 Thanks @rmaynard I needed that crankshaft info also! Share this post Link to post Share on other sites
Hossenfeffa 49 #4 Posted October 29, 2016 Although the 12 hp and 14 hp crankshafts are the same dimensionally, the counter weights on the 12 hp crank are ground flat on the bottom, the 14 hp crankshafts are not. .If you use a 14 hp crank with a 12 hp bore, or visa versa, you will end up with a nice vibrator Share this post Link to post Share on other sites
Shynon 7,491 #5 Posted October 29, 2016 1 hour ago, Hossenfeffa said: Although the 12 hp and 14 hp crankshafts are the same dimensionally, the counter weights on the 12 hp crank are ground flat on the bottom, the 14 hp crankshafts are not. .If you use a 14 hp crank with a 12 hp bore, or visa versa, you will end up with a nice vibrator and then probably some un repairable issues in the near future. Share this post Link to post Share on other sites
BOBTHEBOPPER 3 #6 Posted October 29, 2016 Thanks guys, You answered my question. Good show. Share this post Link to post Share on other sites
