hermitman 116 #1 Posted October 27, 2016 Morning all! Just finishing up our 1-0275, S.N. 807818 with Tecumseh 7 horse. no S.N. found. My problem is.......turns over fine but 1 fuse in fuse block of 3 keeps blowing. It is the fuse in front, sitting vertical. Does anyone know what amp. it should be? Has a 6a in it now. I haven't been able to find a schematic anywhere. Thanks in advance!!! G. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #2 Posted October 27, 2016 Is this fuse block mounted on the engine? Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #4 Posted October 28, 2016 Will guess this is what you are looking at Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #5 Posted October 28, 2016 Can't find a wiring diagram either. This model can't have a complicated electrical system. Possibly a cigar lighter and a wire to charge the battery. Look for thin spots of insulation where vibration has worn the insulation thin exposing the bare wires. If you have a simple test light (contains no batteries) hook it across the 2 terminals that hold the fuse. The probe on one terminal and the alligator clip on the other. As long as the short is present the light should light but think the engine must be running in your case because the charging circuit is what powers the fuse. Any normal electrical load (lights, horn, sirens, battery) will also light the test light. Using a test light just saves you from going through a case of fuses. You may have to disconnect the negative battery cable after the engine is running so you don't get a false light caused by current flow into the battery.. Keep us posted on what you find. Garry 2 Share this post Link to post Share on other sites
hermitman 116 #6 Posted October 28, 2016 thanks a million. soon as the woodstove gets warm ill check it out. have a great day Share this post Link to post Share on other sites
formariz 12,381 #7 Posted October 30, 2016 (edited) Should be a 6 AMP fuse. Here is everything related to it. In your case since you have a fuse it should be schematic #2 in service bulletin 4. Edited October 31, 2016 by formariz Share this post Link to post Share on other sites
