roper 0 #1 Posted October 26, 2016 Would like to install Kohler on my 653. What engine size is good transfer? Share this post Link to post Share on other sites
Racinbob 12,642 #2 Posted October 26, 2016 A K161 or K181 will bolt right in. 4 Share this post Link to post Share on other sites
CasualObserver 3,411 #3 Posted October 26, 2016 just lose the riser plate for the Tecumseh and change the belt guard to one from a Kohler 7/8 Hp tractor (ie...704 855 Commando 8 etc) You'll also have to change the ignition switch if you go with an electric start model. 2 Share this post Link to post Share on other sites
roper 0 #4 Posted October 26, 2016 58 minutes ago, Racinbob said: A K161 or K181 will bolt right in. OK Thank you. 4 minutes ago, CasualObserver said: just lose the riser plate for the Tecumseh and change the belt guard to one from a Kohler 7/8 Hp tractor (ie...704 855 Commando 8 etc) You'll also have to change the ignition switch if you go with an electric start model. OK Thank You. Share this post Link to post Share on other sites
