briankd 833 #1 Posted October 23, 2016 My 12 horse kouler on this is only mounted to frame with 2 bolts on the flywheel side I can see that the engine is wider than the frame. will this be ok? it does have a defiant shake to it when running.(maybe that's why the hood mounting worn out) seen some post on here about shaker plates for these. my stupidity really never caught on is that what I need to mount the engine the way it used to be cause this engine was rebuilt sometime by original horse dealer and maybe this is the way he mounted it Share this post Link to post Share on other sites
Sparky-(Admin) 24,646 #2 Posted October 23, 2016 Are you sure about the two bolts? I bet if ya crawl under it you will see two more bolts going up thru the frame into the bottom of the motor. Mike..... 5 Share this post Link to post Share on other sites
briankd 833 #3 Posted October 23, 2016 ok thanks sparky was working on the electrical and seen this it probably does Share this post Link to post Share on other sites
