Rp.wh 1,103 #1 Posted October 22, 2016 At fleet wondering what the correct spark plug would be for a kohler 12hp Share this post Link to post Share on other sites
Achto 29,663 #2 Posted October 23, 2016 45 minutes ago, Rp.wh said: At fleet wondering what the correct spark plug would be for a kohler 12hp Champion number is RH10 1 Share this post Link to post Share on other sites
Jerry77 1,218 #3 Posted October 23, 2016 Autolite 216 is the same as the champion rh10.....just depends on your preference.. Share this post Link to post Share on other sites
Rp.wh 1,103 #4 Posted October 24, 2016 Thank you for your help worked awesome! Does anyone know what size battery goes it that raider 12? Share this post Link to post Share on other sites
Achto 29,663 #5 Posted October 24, 2016 11 hours ago, Rp.wh said: Does anyone know what size battery goes it that raider 12? When I redid my 1076, I measured the battery box and got a battery that fit that size. Share this post Link to post Share on other sites
Rp.wh 1,103 #6 Posted October 24, 2016 That was my next option , Share this post Link to post Share on other sites
Wheel-N-It 2,976 #7 Posted October 25, 2016 On 10/22/2016 at 8:37 PM, achto said: Champion number is RH10 Question. Would a regular H10 be better for this application (no resistor)? 1 Share this post Link to post Share on other sites
Achto 29,663 #8 Posted October 25, 2016 (edited) 10 hours ago, Wheel-N-It said: Question. Would a regular H10 be better for this application (no resistor)? Kohler book calls for a RH10 but a H10 would work just as well. The H10 might cause a little interference if your trying to listen to a radio station while your using your tractor. Edited October 25, 2016 by achto 2 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #10 Posted October 26, 2016 13 hours ago, achto said: Kohler book calls for a RH10 but a H10 would work just as well. The H10 might cause a little interference if your trying to listen to a radio station while your using your tractor. Reason for asking is I'm curious if the non resistor plug would give a tad more spark with these older ignition systems? Does anyone know about this? Share this post Link to post Share on other sites
Achto 29,663 #11 Posted October 26, 2016 I am not positive, but I believe that the resistor is to suppress electrical interference only. I don't think that it affects the intensity of the spark. 2 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #12 Posted October 26, 2016 18 minutes ago, achto said: I am not positive, but I believe that the resistor is to suppress electrical interference only. I don't think that it affects the intensity of the spark. I'm going to have to do a little research on this. Share this post Link to post Share on other sites
Don1977 605 #13 Posted October 28, 2016 According to Brian Millers site the non resistor will give a hotter spark. It takes less voltage to fire a nonresister. Also indexing the plug toward the intake valve will also give a more complete burn. I have a Autolite 4316 in my 312. 2 Share this post Link to post Share on other sites
pfrederi 18,866 #14 Posted October 28, 2016 I run non resistor plugs as they have proven to work better in my old farm tractors with mags or 6 volt battery ignitions. Also use solid copper core plug wires to make for better spark. If it interferes with some electronic device of some yuppie driving by in his BMW then its too bad....... 6 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #15 Posted October 29, 2016 21 hours ago, Don1977 said: According to Brian Millers site the non resistor will give a hotter spark. It takes less voltage to fire a nonresister. Also indexing the plug toward the intake valve will also give a more complete burn. I have a Autolite 4316 in my 312. Don, I knew you would have some good information for us Share this post Link to post Share on other sites
Achto 29,663 #16 Posted October 29, 2016 Thanks for the learnin'! Share this post Link to post Share on other sites
953 nut 61,613 #17 Posted October 29, 2016 22 hours ago, pfrederi said: use solid copper core plug wires Good point, getting harder to find these days, but well worth it. I picked up a role of the copper plug wire at a Hit & Miss gathering a couple of years ago. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #18 Posted October 29, 2016 29 minutes ago, 953 nut said: Good point, getting harder to find these days, but well worth it. I picked up a role of the copper plug wire at a Hit & Miss gathering a couple of years ago. Thank you for posting this Mr Schmidt. I'm putting this on my shopping list. 1 Share this post Link to post Share on other sites
tunahead72 2,575 #19 Posted October 29, 2016 On 10/27/2016 at 10:43 PM, Don1977 said: ... Also indexing the plug toward the intake valve will also give a more complete burn ... Hey Don, I'm not sure what you mean by this, can you explain? Share this post Link to post Share on other sites
Shynon 7,486 #21 Posted October 29, 2016 Indexing the spark plug will also help to increase power and torque. This is when the open gap faces the center of the piston. It helps in a more thorough combustion of the fuel so the engine will produce more power at high RPM. Indexing washers is used to index a spark plug. They're a copper washer of certain thicknesses that's placed on the threads of the plug. Indexing of the spark plug helps to increase the power on a high-performance engine that operates at high RPM. It doesn't help much on a stock engine or at low RPM. Taken from Brian Millers website 2 Share this post Link to post Share on other sites
squonk 44,386 #22 Posted October 29, 2016 (edited) On 10/28/2016 at 8:59 AM, pfrederi said: I run non resistor plugs as they have proven to work better in my old farm tractors with mags or 6 volt battery ignitions. Also use solid copper core plug wires to make for better spark. If it interferes with some electronic device of some yuppie driving by in his BMW then its too bad....... I 'd be more worried about setting off some girls taser device in her purse! You can buy solid wire and all the fixings at Napa Edited October 29, 2016 by squonk 2 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #23 Posted October 29, 2016 On 10/28/2016 at 8:59 AM, pfrederi said: 27 minutes ago, squonk said: I 'd be more worried about setting off some girls taser device in her purse! You can buy solid wire and all the fixings at Napa Mike, do you buy that wire by the roll or by the foot? What's the cost? Share this post Link to post Share on other sites
squonk 44,386 #24 Posted October 29, 2016 By the feets Fairly cheep. You can get the plug and coil terminal ends, straight and 90 deg boots, even the special pliers for crimping the ends. Pliers are a tad pricey but I have them because I'm a tool hog! 1 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #25 Posted October 30, 2016 Thnk you Mike. I did not know that Share this post Link to post Share on other sites
