briankd 833 #1 Posted October 21, 2016 still has the original ign switch and was going to put a solenoid in with another switch. guy at work said he had some old ford starter solenoids he would give me. he brought me in today a sack of wiring from a old monkey ward tractor says I can have it that it was all working when he took it off. with that being said it has a three prong ign. switch just like my 857 it has a ground strap on switch going to the case on side but it also has a solenoid wired in also even got a real good condition voltage regular with it all just like my 857 uses. question is will this monkey ward ign. switch work on my 857 ? heck it was all free 1 Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted October 21, 2016 That's a hard question to answer with out picks of what ur working with. But as long as you get power to the coil when the ignition switch is turned on and power to the starter solenoid when the key is turned to the start position then it may work. 1 Share this post Link to post Share on other sites
857 horse 2,588 #3 Posted October 21, 2016 About a month or so ago,,,,this model tractor (857) was in a post.....Bob Maynard chimmed in and gave the name of the switch,,,and the part number.... BoB where are you.?? Oh...the name of the switch is a Hersh.??? Nope...ColeHersh !!!!! I think thats it.......Hopfully he will be along....correct me... and save the day.............Hey,,,i just bus tables here..the surgeons are at lunch !!!! I will be back later to check in on the auto correct.!!!!! Howard857 in VA Share this post Link to post Share on other sites
briankd 833 #4 Posted October 21, 2016 21 minutes ago, 857 horse said: About a month or so ago,,,,this model tractor (857) was in a post.....Bob Maynard chimmed in and gave the name of the switch,,,and the part number.... BoB where are you.?? Oh...the name of the switch is a Hersh.??? Nope...ColeHersh !!!!! I think thats it.......Hopfully he will be along....correct me... and save the day.............Hey,,,i just bus tables here..the surgeons are at lunch !!!! I will be back later to check in on the auto correct.!!!!! Howard857 in VA yes there is a cole herssee switch out there but this was free . free is better if it works 1 Share this post Link to post Share on other sites
953 nut 62,628 #5 Posted October 21, 2016 10 hours ago, briankd said: three prong ign. switch just like my 857 it has a ground strap on switch going to the case If the ground is connected to one of the blades where wires connect it is not for your ignition system, presuming you have the battery ignition system. Being free is a good thing if it is the correct part. 10 hours ago, briankd said: old ford starter solenoids Ford solenoid will be fine, The small terminal "S" will connect to the switch; the small "I" terminal will not be used. The Ford unit has a built in ground, lawn equipment has a small terminal that needs to be grounded. This drawing might be helpful. 2 Share this post Link to post Share on other sites
pfrederi 19,089 #6 Posted October 21, 2016 The ground strap makes it sound to me like the tractor it came from had a magneto ignition. 2 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #7 Posted October 23, 2016 On 10/21/2016 at 7:27 AM, pfrederi said: The ground strap makes it sound to me like the tractor it came from had a magneto ignition. alot of monkey wards that use a ground strap did instead have a mag n points setup. they were equipt with cast iron briggs if it was a gilson (made alot of machines for montgomery wards) that it was removed from Share this post Link to post Share on other sites
briankd 833 #8 Posted October 24, 2016 well did some work on it today the ign. switch from the monkey wards won't work wrong style. the solenoid though will work got it all wired just going to get a ign switch sometime this week . I have another switch I bought for my jd 110 but it for a k 181s mag ignition the guy will trade me for a coil style ign. switch. it will be good to go then. Thanks Everyone for the help Share this post Link to post Share on other sites
