RJ Hamner 1,028 #1 Posted October 12, 2016 (edited) I ran across a deal on a 1968 Raider 12 that was all original (even had Wheel Horse tires). Brought it home and degreased it and had set it aside until I finished the C-121 project. I had to send my every day mower to the shop and had to use the Raider to mow the lawn and was cleaning it off when I noticed that the base of the K301 was wider that the frame of the WH and its only bolted to the frame with 2 bolts!! Is that normal??? Or, am I missing a part??? Edited October 12, 2016 by RJ Hamner forget to select notify Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted October 12, 2016 NORMAL !!!! 2 bolts go up thru the frame. 3 Share this post Link to post Share on other sites
RJ Hamner 1,028 #3 Posted October 13, 2016 Well that's a relief. Thanks!!!! Share this post Link to post Share on other sites
Ed Kennell 44,095 #4 Posted October 13, 2016 No problem RJ, just another symptom of the dreaded WHA disease. We all think we're a couple bolts short of a full set. 2 Share this post Link to post Share on other sites
953 nut 63,569 #5 Posted October 13, 2016 1 minute ago, Ed Kennell said: We all think we're a couple bolts short of a full set. Hay!!!!! Watch it there Ed; I resemble that remark. 2 Share this post Link to post Share on other sites
Ed Kennell 44,095 #6 Posted October 13, 2016 Nothing personal Dick, but if the missing bolt fits..... This is my own two scents and the pinions and concussion I have formed after reeding these posts and inhailin too much Kohler exhaust for two many jears. Maybe that's why I lost the spellin bee. 2 Share this post Link to post Share on other sites
TDF5G 2,073 #7 Posted October 13, 2016 15 hours ago, RJ Hamner said: the base of the K301 was wider that the frame of the WH and its only bolted to the frame with 2 bolts!! I thought the same thing after I bought a B100 to put back together. I eventually figured it out. Share this post Link to post Share on other sites
953 nut 63,569 #8 Posted October 13, 2016 14 hours ago, Ed Kennell said: my own two scents and the pinions and concussion I have formed after reeding these posts and inhailin too much Kohler exhaust for two many jears. 14 hours ago, Ed Kennell said: I lost the spellin bee. You didn't win because you were in the wrong spellin bee; you should have ben in the ebonics bee! 2 Share this post Link to post Share on other sites
