Devron30 22 #1 Posted October 10, 2016 (edited) I am using my c100 for plowing and other jobs and need to weight down the front end. Does anyone know of a bracket for suitcase weights or anything else I can use. Thank you. Edited October 10, 2016 by Devron30 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted October 10, 2016 I don't think WH actually made a bracket, but many people custom make their own. Did you do a search for "front weight bracket" here? Share this post Link to post Share on other sites
C-101plowerpower 1,606 #3 Posted October 10, 2016 i made my own, http://myoldmachine.com/topic/2415-wheel-horse-front-weight-from-bits-n-bobs/ 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,461 #4 Posted October 10, 2016 You don't see them very often Garry 1 Share this post Link to post Share on other sites
Devron30 22 #5 Posted October 11, 2016 Thanks guys. I hope to see if someone sells this in the after market form. Share this post Link to post Share on other sites
wallfish 20,511 #6 Posted October 11, 2016 How about filling the front tires with RV antifreeze and adding wheel weights. 1 Share this post Link to post Share on other sites
Devron30 22 #7 Posted October 11, 2016 Just now, wallfish said: How about filling the front tires with RV antifreeze and adding wheel weights. Do they make front wheel weights? Share this post Link to post Share on other sites
Devron30 22 #9 Posted October 11, 2016 Just now, wallfish said: Sure do Thanks. I'll have to get my tire size and look into it Share this post Link to post Share on other sites
wallfish 20,511 #10 Posted October 11, 2016 Original front rims for a C101 are 8" so you'll need weights to fit those. Other brands will fit too but some are are too deep in the center and will hit the spindle so keep that in mind. This is the only pic I could find of mine. They are Bolens weights on the loader tractor. 4 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,589 #11 Posted October 11, 2016 Look in the for sale section here. A member had a set of front weights I think. They weren't wheel horse, but they would fit. You might catch them still listed way way near the end. Good luck. Glenn Share this post Link to post Share on other sites
Tim 97 #12 Posted October 12, 2016 (edited) Google "Noma wheel weights $50 plus shipping" I bought two sets Good news they are the cheapest you will find Bad news you have to drill new holes that line up to holes of wheels so you can bolt on. I had a WH weight set to line up the new holes made it very easy Edited October 12, 2016 by Tim 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #13 Posted October 12, 2016 My front suitcase weight hanger bracket that I made for my 520 fits B,C,3/4/500 series and I have thread with plans/blueprint to make them,Jeff. 5 Share this post Link to post Share on other sites
cschannuth 3,821 #14 Posted October 12, 2016 I have one of Jeff's hanger brackets and they are the best I've seen. Share this post Link to post Share on other sites
Devron30 22 #15 Posted October 12, 2016 13 hours ago, WVHillbilly520H said: My front suitcase weight hanger bracket that I made for my 520 fits B,C,3/4/500 series and I have thread with plans/blueprint to make them,Jeff. Those are awesome! Great work! I need to find me some of those 😀 1 Share this post Link to post Share on other sites
C-85 817 #16 Posted October 12, 2016 This is what I added for a front weight, it's independent of the plow C-85 4 Share this post Link to post Share on other sites
cschannuth 3,821 #17 Posted October 12, 2016 3 hours ago, C-85 said: This is what I added for a front weight, it's independent of the plow C-85 If your wife is like mine she probably loves having things like that on her kitchen counters. LOL 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #18 Posted October 12, 2016 9 hours ago, Devron30 said: Those are awesome! Great work! I need to find me some of those 😀 The weights are actually a "JD" product approximately 42-3 lbs each not certain may be sold at Home Depot also and here's the plans (for the 3/4/500 series might have to adjust as necessary to fit the c101 if it's a black hood as did for Craig) if you are willing to fab one up or have it made since I moved departments at work and no longer have access to make them,Jeff. 2 Share this post Link to post Share on other sites
Devron30 22 #19 Posted October 14, 2016 Thanks guys for all the help! Share this post Link to post Share on other sites
bds1984 1,516 #20 Posted October 14, 2016 I had some 25 pound plate weights from an old weight set that I drilled two holes in them to mount them as my front weights on the front rims of my 520 plow tractor. I'd use a suitcase setup but I have a stabilizing rod taking up the front quick attach to keep the plow stable. Share this post Link to post Share on other sites
Tankman 3,528 #21 Posted October 15, 2016 (edited) After my first plow job, turning the earth, made a front bumper and added weights. A must! Not a great pic, sorry. My oldest son, 30 years ago Edited October 15, 2016 by Tankman Share this post Link to post Share on other sites
Devron30 22 #22 Posted October 20, 2016 I need to find someone who makes some kind of front weight system for my c100 because I am no fabricater and wouldn't even know where to start. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #23 Posted October 22, 2016 Is there a metal fab or machine shop nearby you? If so copy/print my plans and take them there, not sure but may be selling 1 more of mine, and I want you to know that these are only for ballast when using rear/clevis hitch mounted implements, the snow plows won't raise with these type of weights hanging off the front but then there's the rare WH version,Jeff. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #24 Posted October 29, 2016 Here's a pic of the factory front weight/bracket in use with mule drive/mower attached (BTW not mine),Jeff. 1 Share this post Link to post Share on other sites
