fordsonmajortom 1 #1 Posted January 3, 2009 Can anybody tell me what the dimensions are of the brake shaft oilseal on a 1974 8speed. The part number may not be any good as it might not be recognized over here in England, if i give them the dimensions my supplier will probobly be able to match it up. Thanks Share this post Link to post Share on other sites
Cody 277 #2 Posted January 3, 2009 I just picked up a brake seal for my 75 8 speed. The seal measures 1" outside diameter and 11/16" inside diameter. hope this helps Share this post Link to post Share on other sites
fordsonmajortom 1 #3 Posted January 4, 2009 Many thanks for the dimensions Cody , It wasn't leaking before I took the tractor to pieces and now it weeps a bit onto the floor. Share this post Link to post Share on other sites
Stigian 1,235 #4 Posted January 4, 2009 Thanks for the reminder Michael, i really should fix the same problem on my Raider 10 But hey, at least it only leaks when the tractor is parked up on un-level ground and is leaning to one side :hide: Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted January 4, 2009 But hey, at least it only leaks when the tractor is parked up on un-level ground and is leaning to one side Why dont you just park it the other way round? :D Share this post Link to post Share on other sites
