ahartman21 0 #1 Posted October 3, 2016 I am new to this but here is my problem.........I put the drive belt back on, started it up just fine, the pulleys and belts are moving. I put it into gear and no movement. Also I can put it into gear without moving the clutch with no grinding but no movement, which I believe is the problem. The belt moves when pressing the clutch in. But I figured if I can put it into gear without the clutch and without a grinding noise, Something is not grabbing.....on a side note my seat switch is now on which wasn't before and the odd thing is the wires to the seat switch is disconnected......stumped Share this post Link to post Share on other sites
Digger 66 3,525 #2 Posted October 3, 2016 (edited) Welcome to Redsquare What kind of tractor is it Sounds like you may have mis-routed the drive belt . Edited October 3, 2016 by Digger 66 Share this post Link to post Share on other sites
ahartman21 0 #3 Posted October 3, 2016 312 1989 wheelhorse Share this post Link to post Share on other sites
scotty 252 #4 Posted October 3, 2016 (edited) I would check the keyway on the input shaft pully kind of sounds like it may of sheared for the not grinding part. Also is your belt guard installed? You have to have it on for the belt to stop. Edited October 3, 2016 by scotty Share this post Link to post Share on other sites
ahartman21 0 #5 Posted October 3, 2016 Yea the belt guard is on Share this post Link to post Share on other sites
Walt 339 #6 Posted October 3, 2016 Welcome to Red Square. Did it work okay before changing the belt? If so and only change is the new belt I would double check belt length since it only goes around 3 pulleys hard to route it wrong. Share this post Link to post Share on other sites
ahartman21 0 #7 Posted October 3, 2016 It was the same belt that was on it. It had fell off Share this post Link to post Share on other sites
wildman 205 #8 Posted October 3, 2016 What Digger 66 said Share this post Link to post Share on other sites
Retired Wrencher 6,457 #9 Posted October 4, 2016 (edited) ahartman21 Did the tractor ever work or move before? Edited October 4, 2016 by T1257 RETIRED WRENCHER. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #10 Posted October 4, 2016 Keyway on the transmission input shaft is probably sheared, or the belt is not the right size or completely worn out. Keyway on the transmission input shaft is probably sheared, or the belt is not the right size or completely worn out. 1 Share this post Link to post Share on other sites
