mikeeyre74 290 #1 Posted October 2, 2016 I have had several different tractors from the late 70s to the lead… Every time I try to move one of the mower decks to another tractor, it seems to be variable and mysterious which hole in the lift arm down below (that the deck attaches to the lift rod), and which hole on on the handle that you pull on that you're supposed to use. For instance, do I use the forward most hole or the rear most hole to attach the chain/J hook trunnion ? And on the lift handle itself, there are three holes that I can use… Do I use the one closest to the handle or farthest away or the one in the middle? I Can't find anything in any of the user manuals or deck manuals in regards to this. Share this post Link to post Share on other sites
stevasaurus 23,746 #2 Posted October 2, 2016 See if this helps... 4 Share this post Link to post Share on other sites
