T-Mo-(Moderator) 4,611 #1 Posted September 28, 2016 I know some of the older Wheel Horses probably has tons and tons of hours on them, but without an hour meter, it's hard to tell how many they have. But, just for discussion sakes, how many hours do you have on your Wheel Horse, if it has an hour meter. My '88 416-8 that I picked up in June has over 3600 hours, and I'm sure the engine and transaxle is original to the tractor. I should go and take a picture of the actual hours on it to document it, but it reads over 3600 hours. It still runs and drives good, but does smoke some on startup. Sorry if this topic has been brought up before as I did do a search, but couldn't find a specific topic on it. I did find threads asking how many hours on this model, this engine, etc., but no specific thread on actual hours of owner's machines, except for this one: 5 Share this post Link to post Share on other sites
bmsgaffer 2,053 #2 Posted September 28, 2016 I would love to know how many hours are on my 854, that I am FAIRLY sure has original engine un-rebuilt (though it needs it now). The triple pully had nearly a 1/8" deep belt groove on both outside "slots" as it had been flipped once it was worn too bad. I assume your 416 is a Kohler? That's a LOT of hours! 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #3 Posted September 28, 2016 My 854, hours wise, who knows, the great unknown. Now my 1988 416-8 has about 670 hours on it, bought from the original owner. So I guess with proper care I have plenty hours to go. Good topic. Glenn 1 Share this post Link to post Share on other sites
wrightorchid 261 #4 Posted September 28, 2016 What was the first horse to get an hour meter? 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #5 Posted September 28, 2016 i sure with i knew how many was on my dads 502. its been through 4 engines that we know of 1 front axle and a trans lol 2 Share this post Link to post Share on other sites
wallfish 18,191 #6 Posted September 28, 2016 My 418 has over 2500 on the meter but the key was left on a couple of times until it completely killed the battery so that racked up quite a bit of them. 2 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,611 #7 Posted September 28, 2016 1 hour ago, bmsgaffer said: I would love to know how many hours are on my 854, that I am FAIRLY sure has original engine un-rebuilt (though it needs it now). The triple pully had nearly a 1/8" deep belt groove on both outside "slots" as it had been flipped once it was worn too bad. I assume your 416 is a Kohler? That's a LOT of hours! 16 hp Kohler Magnum M16. A Magnum is about as close to a K-Series without being a K-series as you can come, since it's the direct replacement for the K-series. 1 hour ago, JERSEYHAWG / Glenn said: My 854, hours wise, who knows, the great unknown. Now my 1988 416-8 has about 670 hours on it, bought from the original owner. So I guess with proper care I have plenty hours to go. Good topic. Glenn Since my '88 416-8 has over 3600 hours, yours with 670 hours is basically brand new. 3 Share this post Link to post Share on other sites
elliot ness 1,916 #8 Posted September 28, 2016 I had a 520H with 2100hrs, and it still run good. My C-195 has 1250hrs. I would bet that some of the 60's models would have 4000+ hrs or maybe more. 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #9 Posted September 28, 2016 My 312 has 1906 hours. No noticeable smoke but does consume some oil between changes. Share this post Link to post Share on other sites
muz123 1,192 #10 Posted September 28, 2016 My 1983 C-175 has 1503 hours and needs a coil which i ordered but other than that its fine. Share this post Link to post Share on other sites
slammer302 2,156 #11 Posted September 29, 2016 417-8 has almost 1500hrs does smoke sum on start up. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #12 Posted September 29, 2016 12 hours ago, wallfish said: My 418 has over 2500 on the meter but the key was left on a couple of times until it completely killed the battery so that racked up quite a bit of them. John, I did not know you have a 418. Its good to know the M18 engine will go that many hours if it is taken care of. My 418-8 has the most hours of the herd at just a hair over 1200. I think its a bit odd that the Magnum powered 312 and 416 have hour meters, yet the Magnum powered 414 does not. Can anyone comment on that observation? Share this post Link to post Share on other sites
slammer302 2,156 #13 Posted September 29, 2016 I think it depends on what year they were made the 90's models seem to have hrs meters I had a 314-8 & 314-h both had meters. Never had a 414 though. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #14 Posted September 29, 2016 My 414 does not have an hour meter ( like the 310-8 ) and several other 414's I've seen up close do not have them either. Come to think of it my 414 does not have tail lights, but it does have rear reflectors. Maybe that was Wheel Horse's way to help lower the cost of a 400 series tractor by offering one with 14hp, no tailights, and no hour meter. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,611 #15 Posted September 29, 2016 So far, my 416-8 has the most documented hours on it. As mentioned, some of the earlier tractors without an hour meter might approach way more hours than mine. I hope more chime in with their numbers. Share this post Link to post Share on other sites
wallfish 18,191 #16 Posted September 29, 2016 10 hours ago, Wheel-N-It said: John, I did not know you have a 418. 418-C is my designated snow blower machine. 2 stage blower with a glass window cab. A 418-C is the commercial version. It's a dumbed down 418-A without all the frills but faster. 1 Share this post Link to post Share on other sites
clueless 3,258 #17 Posted September 29, 2016 Picked up a 312-8 a few years ago, 575hr on it, original owner said lights didn't work. This was my first one with hour gauge, got it home and got the lights working. Couple of weeks later I decided to see how well it cut grass, damn, left the key on battery died. While I was charging the battery, notice the hour gauge 220 more hours on a tractor that hadn't moved. My point, unless you are the original owner you don't really know hour many hours are on the engine, no matter what the gauge reads. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #18 Posted September 29, 2016 9 hours ago, wallfish said: 418-C is my designated snow blower machine. 2 stage blower with a glass window cab. A 418-C is the commercial version. It's a dumbed down 418-A without all the frills but faster. John, please please please post some pics of your 418 ! Or just text them to me. Either way I'll be happy Share this post Link to post Share on other sites
Pollack Pete 2,273 #19 Posted September 29, 2016 My 312-8 that has lawn mowing duty has 3516 hrs.Barely a slight puff of blue smoke on start-up.Runs like new. 1 Share this post Link to post Share on other sites
Molon_Labe 731 #20 Posted September 30, 2016 My '88 416-8 M16 as of a couple of years ago. 1865 hours now and still runs great. 2 Share this post Link to post Share on other sites
Al C. 1,428 #21 Posted September 30, 2016 My 1067 has the original K241 10hp with about 1400 hours on it (dad bought it new in 1967). Starts fast on first crank, no smoke, plenty of power - nothing slows it down. Took the head off for the first time this summer. Cleaned out some carbon. Otherwise, metal and clearances look like new. 3 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #22 Posted September 30, 2016 I bought a 520-H with a bit over 2900 on it and it still runs. Share this post Link to post Share on other sites
DennisThornton 4,771 #23 Posted September 30, 2016 1 hour ago, WNYPCRepair said: I bought a 520-H with a bit over 2900 on it and it still runs. Brian, does that 520 have any visible smoke? Starting, stopping or under load? Share this post Link to post Share on other sites
DougC 2,643 #24 Posted September 30, 2016 I bought my '95 520H as a demo with 25 hours on it in '97 from my Toro Dealer and now has just turned 1,100 hours. No oil consumption or smoke. I mowed and pushed snow with it. I bought my '88 520H last October with 1,343 hours on it in an attempt to keep the hours from racking up so fast on the '95. It just turned 1,400 hours. I did lot's of repairs over the last year to get it work ready. I will be mowing with it and this winter mount the single stage snow thrower and make a snow drift remover out of it. It uses some oil and will puff a little smoke when starting a warm engine. P.O did not keep it serviced and just used it to till his garden in the spring. It came with the tiller mounted and operational. A 48" deck and short chute snow thrower. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #25 Posted September 30, 2016 3 hours ago, DennisThornton said: Brian, does that 520 have any visible smoke? Starting, stopping or under load? I bought it as a parts tractor, so it hasn't driven much. I didn't notice it smoking, but I wasn't really looking hard either. Share this post Link to post Share on other sites
