WH520 17 #1 Posted September 26, 2016 Hi everyone, it's been awhile since I've been here. I'm having some issues with my 93 312 with the 12 horse Kohler. Last weekend I went to start it and it wasn't firing at all so I sprayed some carb cleaner in the carb and it fired up for a second but wouldn't restart. I pulled the fuel lines off the fuel pump and had gas going to the pump. I left the line off the pump on the side that goes to the carb and turned it over and gas came shooting out. I hooked the line back and it started right up and ran great for the hour it takes to mow my yard. Fast forward to this weekend. I went out to mow the grass and it's doing the same thing again, not firing. I pulled the line off the pump and turned it over but this time there is no gas being pumped out. I tore the pump apart and from what I could tell everything looked ok. I could hear the check valve clicking on the inlet side when I blew into it. I tried sucking on the outlet side but I couldn't hear anything. I didn't get very good suction on it though because, well, gas fumes don't taste very good lol. Does anybody have any suggestions? Is there a rebuild kit for these or can you still buy a fuel pump? I tried looking them up but didn't have much luck. Thanks guys, sorry for the long post! Share this post Link to post Share on other sites
Ed Kennell 45,732 #2 Posted September 26, 2016 Do you have a good supply of fuel to the pump? The tank shut off valves have a screen inside the tank that gets clogged. If the valves in the pump are sealing properly, you should be able to blow air through the inlet but not through the outlet...a bit safer than sucking on the inlet. New pumps are available for around $40. NAPA, Jacks small engine, Amazon, etc. 2 Share this post Link to post Share on other sites
WH520 17 #3 Posted September 26, 2016 (edited) That's good to know, I didn't know there was a screen there. As a matter of fact I did try blowing in the outlet and no air came out. I had forgotten I did that. When I took the line off coming from the tank no gas would come out while I held the line straight up and down (like the position it would be in connected to the pump) It would only start to come out when I got it almost horizontal with the engine. It seemed to be a pretty steady stream coming out though. Edited September 26, 2016 by WH520 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #4 Posted September 26, 2016 You should take the float bowl off the carb while you are at it. After dumping out the old gas, take some spray brakekleaner and spray up in the bottom of the carb to clean the float area. Wear safety glasses so you don't get the stuff in your eyes and dry your eyeballs out. Share this post Link to post Share on other sites
Tonyp 285 #5 Posted September 26, 2016 (edited) remove the fuel pump, it's easy, , remove the gas lines, remove two screws on the front of the engine block. take it apart, slowly and carefully ( 4 screws) don't mess with the gasket..note the position of the input and output check valves, take them out, clean them and put them back in "snug" same as they came out. Before you remove them note if the input check valve is slightly "unseated". In all honesty this is about a 20 to 30 min ordeal but if you are not pulling gas from the fuel tank you need to check it. Also be sure your gas line/filter is fresh and the fittings are indeed TIGHT. I have had this exact same issue many times and fought the battle only part way. I finally decided to install a new gas line, new filter, new HOSE CLAMPS , removed the fuel pump, serviced the check valves and all is well. Engine starts on a half a crank every time now, as it should. But I am replacing the fuel pump/ check valves soon. After all they are 30 years old ! If the fuel pump loses prime it's very difficult to get it back Edited September 26, 2016 by Tonyp 2 Share this post Link to post Share on other sites
WH520 17 #6 Posted October 15, 2016 Hi guys, I figured I'd give an update. I ordered a new pump from NAPA and installed it yesterday and it fired right up! Now I've got an issue with one of the deck spindles, always something lol Thanks everybody for your help. 1 Share this post Link to post Share on other sites
WH520 17 #7 Posted June 18, 2017 (edited) Hi guys, thought I'd give an update and ask a question. I replaced the fuel pump last fall and mowed my yard twice before the new pump quit working on me. So fast forward to a few weeks ago. I ordered another fuel pump, replaced the fuel lines and put a new petcock on the tank. The tractor fired right up and was running good. Again, I mowed the yard twice and now it's not pumping fuel again. It's getting a good fuel flow from the tank to the pump. Whats the the chances of getting 2 bad pumps and only getting 2-3 hours out of them ? Am I doing something wrong on installation? I just ordered another pump off eBay, I thought I'd try to get some tips off the experts here. Edited June 18, 2017 by WH520 Share this post Link to post Share on other sites
953 nut 65,210 #8 Posted June 18, 2017 Are you using ethanol free gas? If not, go to buyrealgas.com and find a station that sells it. Ethanol will kill the fuel system on small engines. Another possibility would be the vent in the gas cap, if the vent is bad the fuel leaving the tank will create a slight vacuum that the pump can't overcome. Share this post Link to post Share on other sites
WH520 17 #9 Posted June 18, 2017 I forgot to mention I also got a new fuel cap since the old one was cracked. I have been using ethanol gas, there is a station not far from me that sells non ethanol, I've just never tried it. Maybe I'll drain the gas out of the tank and fill it up with non ethanol when I put the new pump on. 1 Share this post Link to post Share on other sites
Ed Kennell 45,732 #10 Posted June 19, 2017 Do the pumps work when you pump the levers by hand? If they do, you may have a worn cam lobe. Go electric. 1 Share this post Link to post Share on other sites
WH520 17 #11 Posted June 19, 2017 I did try pumping them by hand but wasn't getting any suction. However, on the current pump when I plugged both the inlet and outlet I would get a puff of air come out of both sides. Electric is my next step if I have the same problem with the new pump, I was just wanting to try to try to keep it original if I could. Share this post Link to post Share on other sites
953 nut 65,210 #12 Posted June 19, 2017 Electric is the way to go! Share this post Link to post Share on other sites
WH520 17 #13 Posted June 23, 2017 Got the new pump and installed it today. It started right up and I let it ran for half an hour. I'll let you guys know if it still starts when I go to mow the yard in 3 weeks. So far I've only been getting 2 weeks out of them lol 1 Share this post Link to post Share on other sites
WH520 17 #14 Posted July 9, 2017 So far so good with the new pump. I've gotten twice the life out of it so far than the other ones.....I've mowed the yard 4 times with it lol 3 Share this post Link to post Share on other sites
voldavid 0 #15 Posted July 14, 2017 On 7/9/2017 at 2:23 PM, WH520 said: So far so good with the new pump. I've gotten twice the life out of it so far than the other ones.....I've mowed the yard 4 times with it lol looks great ! hope it keeps it up! Share this post Link to post Share on other sites
WH520 17 #16 Posted July 15, 2017 On 7/13/2017 at 9:57 PM, voldavid said: looks great ! hope it keeps it up! Thanks. Unfortunatley I must have cursed myself. I just went to start it and....no fuel lol. Looks like it's time to put an electric pump on it. 1 Share this post Link to post Share on other sites
Kurt-NEPA 756 #17 Posted July 15, 2017 +1 for an Electric Fuel pump. I've switched my 3 over to electric. My 520xi would take forever to start with the stock fp. Now it starts on the first revolution. The improvement is really significant on a cold winter morning with 20 inches of snow in the driveway. Share this post Link to post Share on other sites
MikeT 6 #18 Posted July 17, 2017 Don't want to hijack this thread but I am having the same no start issue with my 314-8, I have done exactly the same things and other than purchasing 3 pumps. I was just about to buy a pump before I read this. where would I find an electric pump for my tractor , I think I would rather change to electric than cross my fingers with a mechanical pump Share this post Link to post Share on other sites
Kurt-NEPA 756 #19 Posted July 17, 2017 I used an Airtex E8016S Universal Electric Fuel Pump (a low pressure pump). Best price I found was on Amazon. Also, I wired it using a relay. Try to place the pump as low on the tractor as you can, that way it primes easily. The hard part is always finding a place to put the pump. They are bigger than you think and space is limited. Share this post Link to post Share on other sites
