Detector 72 #1 Posted September 21, 2016 (edited) Should the fuel line hold down be under the bracket or above it under the bolt itself? I'm thinking it goes under the bolt but not sure, was like this when I purchased it Edited September 22, 2016 by Detector Share this post Link to post Share on other sites
Detector 72 #2 Posted September 22, 2016 (edited) I looked at a parts diagram and it appears to go under the rear bolt and not under the cable tube hold down plate as it is now, looks like a gap for water and rust. I'll add liquid teflon to these two bolts Edited September 22, 2016 by Detector Share this post Link to post Share on other sites
WHX?? 53,091 #3 Posted September 22, 2016 Mine is on top from the factory but not sure if it matters. I would say on top just to get the hold down plate to sit flat. Yours looks pretty clean but make sure dirt & crap doesn't fall down the hole into the tranny. Also not sure if the Teflon is needed as I never had any leakage in that area but probably doesn't hurt. 1 Share this post Link to post Share on other sites
Detector 72 #4 Posted September 22, 2016 5 hours ago, WHX7 said: Mine is on top from the factory but not sure if it matters. I would say on top just to get the hold down plate to sit flat. Yours looks pretty clean but make sure dirt & crap doesn't fall down the hole into the tranny. Also not sure if the Teflon is needed as I never had any leakage in that area but probably doesn't hurt. Thanks, trying to get everything back as close to original as I can Share this post Link to post Share on other sites
WHX?? 53,091 #5 Posted September 22, 2016 Your welcome Share this post Link to post Share on other sites
